Weirdest thing...
Old Aug 21, 2003 | 04:10 PM
Ziggie's Avatar
Default Weirdest thing...
The volume of my music flucuates while I'm driving. When I slow down to a stop the volume goes down a little. Then when I speed up again the volume increases?
Any idea what might cause this? I've heard there is an option on some decks to do this. I don't think it's the deck because it just started happening and I didn't change the settings on my headunit. I'm thinking it has something to do with the battery and/or alternator? This volume change just started happening after I installed my 2 12's and 800 watt pioneer amp. Any help is appreciated thanks.
Old Aug 21, 2003 | 08:42 PM
hotboi850's Avatar
Default Re: Weirdest thing... (Ziggie)
possible you dont have enough amps to run your setup. Car alternator produces more while on the throttle. but when at idle it does down. does ur lights dim down?
Old Aug 21, 2003 | 09:24 PM
kitkat77's Avatar
I've heard of people having that problem. A capacitor might help.
Old Aug 24, 2003 | 06:38 AM
LANDYcolorLAB's Avatar
Sounds like a battery alternator problem. Go with the previous post about if your lights dim as well then brighten.
Old Aug 24, 2003 | 05:19 PM
ScareyH22A's Avatar
Honda-Tech Gold Member
Community Builder
Is it a Pioneer deck? If it is, keep pressing the "Audio" button until the menu with "ASL" (automatic sound levelizer) appears. Press left or right to adjust the sensitivity of the ASL from Low-Mid-High or press down or up to turn On or Off.
The ASL is also used on factory Mark Levinson systems from Lexus.
Old Aug 24, 2003 | 09:50 PM
whiteboygsr's Avatar
Default Re: Weirdest thing... (ScareyH22A)
Factory Miatas do it too. Check for a sound-leveling option in your deck like ScareyH22A said. most likely your problem lies there.
Old Aug 25, 2003 | 07:18 AM
rjr162's Avatar
Default Re: Weirdest thing... (whiteboygsr)
as does the ford focus and older JVC units
Old Aug 25, 2003 | 07:55 AM
1.8monster's Avatar
yea there are a few cars out there that do that. the radio is hooked up to the tach so when your rpm's go up then so does your radio. what kinda car do you have?
adrimirko
Apr 9, 2015 07:01 PM
mikej94civex
Dec 30, 2009 02:53 AM
SkIp_Civic_Ek6
Jan 30, 2008 08:11 PM
redman223
Audio / Security / Video
24
Aug 12, 2003 09:47 AM
accordv6lx
Aug 31, 2001 07:20 PM
