Civic Wheel Spacers
Old Feb 6, 2007 | 05:40 PM
SoCal EJ1's Avatar
Default Civic Wheel Spacers
Just put on my wheels today and I decided I'm going to get wheel spacers in the rear. Think 5mm is enough? or should I look for 8mm or 10mm? They're 16x7, +42 offset.
Also, some come with extended wheel studs... Is it highly recommended to use these? I ask because I don't know the quality and don't want to jeopardize strength.
Old Feb 6, 2007 | 06:52 PM
SoCal EJ1's Avatar
up
Old Feb 6, 2007 | 07:05 PM
r.wright's Avatar
Default Re: (SoCal EJ1)
are you rubbing tire the rr?
Old Feb 6, 2007 | 09:11 PM
SoCal EJ1's Avatar
Default Re: (mr. rlx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr. rlx &raquo;</TD></TR><TR><TD CLASS="quote">are you rubbing tire the rr?
If you're asking if I'm rubbing, no.
Old Feb 6, 2007 | 09:52 PM
r.wright's Avatar
then a 3mm or 5mm will be fine w/o those new studs
Old Feb 7, 2007 | 06:45 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Civic Wheel Spacers (SoCal EJ1)
You need at least six full turns on the lug nuts (although 6.5-7.0 is even better). If you don't have them after putting the spacers on, then you will need to get extended studs.
Old Mar 13, 2007 | 03:54 AM
George Knighton's Avatar
H-T Order of Merit
Default Re: Civic Wheel Spacers (nsxtasy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">You need at least six full turns on the lug nuts (although 6.5-7.0 is even better). If you don't have them after putting the spacers on, then you will need to get extended studs.</TD></TR></TABLE>
Ken, in your experience, do people have enough thread with OEM Honda studs and, say, a 5mm spacer and the typical wheels that people use? (Spoon, Volks, Kosei, etc.)
Is there a particular 5x114.3 5mm spacer that you are comfortable recommending?
Old Mar 15, 2007 | 10:29 AM
GloomyX's Avatar
a quick noob question,
since he ain't rubbing, why is he putting on spacers in the back?
Old Mar 15, 2007 | 03:46 PM
old man neri's Avatar
Default Re: (GloomyX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GloomyX &raquo;</TD></TR><TR><TD CLASS="quote">a quick noob question,
since he ain't rubbing, why is he putting on spacers in the back?</TD></TR></TABLE>
I would assume for looks or the misconception that a 5mm wider stance will improve performance. To each his own.
Old Apr 7, 2007 | 07:08 AM
neof69's Avatar
Default Re: Civic Wheel Spacers (George Knighton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton &raquo;</TD></TR><TR><TD CLASS="quote">
Is there a particular 5x114.3 5mm spacer that you are comfortable recommending?</TD></TR></TABLE>
I too, would like to know this as well....
instrument
10
Oct 1, 2007 04:55 PM
b20integrapower
Mar 18, 2006 08:28 AM
gakkuken
21
Jan 10, 2005 02:28 PM
Tommy_Gunns
Jul 24, 2004 09:53 PM
zRd#1
May 14, 2003 11:46 PM
