wheel balancing
Old Mar 17, 2006 | 01:28 PM
b20integrapower's Avatar
Default wheel balancing
if i switch tires...do i have to have my wheels re balanced?
Old Mar 17, 2006 | 01:32 PM
IN VTEC's Avatar
Default Re: wheel balancing (b20integrapower)
Yes. The heavy spot won't be in the same spot and even then, the tire might have a different mass distribution all together. You need to rebalance when you put a different tire on a rim.
Old Mar 17, 2006 | 02:16 PM
IVI's Avatar
IVI
Default Re: wheel balancing (IN VTEC)
any time the bead is broken you'll need to rebalance the wheel.
Old Mar 17, 2006 | 04:12 PM
integra3586's Avatar
Default Re: wheel balancing (IVI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IVI &raquo;</TD></TR><TR><TD CLASS="quote">any time the bead is broken you'll need to rebalance the wheel.
only if the tire moves on the rim
Old Mar 17, 2006 | 05:20 PM
IVI's Avatar
IVI
Default Re: wheel balancing (B18B-SC)
its up to you then i guess.
ive balanced a wheel after breaking the bead without touching the weights or moving the tire, and it did not come 0/0.
Old Mar 17, 2006 | 05:39 PM
wat do u mean by breaking the bead?
Old Mar 17, 2006 | 06:36 PM
nickG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20integrapower &raquo;</TD></TR><TR><TD CLASS="quote">wat do u mean by breaking the bead?</TD></TR></TABLE>
after you let the air out, you use a machine to push the sidewall away from the wheel and then you can take the tire off....
but you should rebalance if you take the take the tire off and put it on a different wheel...we marked the valvestem and the weights if we wanted to put the tire back on the same wheel..
Old Mar 17, 2006 | 11:07 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IVI &raquo;</TD></TR><TR><TD CLASS="quote">its up to you then i guess.
eh, it probably was out of balance to start with then
Old Mar 18, 2006 | 08:28 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I also agree that any time a tire is removed from a wheel, the wheel/tire will need to be rebalanced after re-mounting the tire or mounting a new tire.
shotgun2224
Aug 18, 2007 10:03 PM
Bubble Gum Jr.
Jun 1, 2007 05:22 PM
lrcrx90
Mar 10, 2007 05:25 PM
Don Jefe
Jan 11, 2006 12:31 AM
Tommy_Gunns
Jul 24, 2004 09:53 PM
