Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
purpose of extended wheel studs
Old Apr 25, 2004 | 11:21 AM
gakkuken's Avatar
Default purpose of extended wheel studs
can someone kindly explain the purpose of extended wheel studs?
thanks so much!
Old Apr 25, 2004 | 11:22 AM
Knestis's Avatar
Default Re: purpose of extended wheel studs (gakkuken)
They provide room for spacers behind the wheels and make wheel changes easier during pit stops.
K
Old Apr 25, 2004 | 08:27 PM
siisgood00's Avatar
New User
Default Re: purpose of extended wheel studs (Knestis)
I heard they look pretty slikk too.
Old Apr 25, 2004 | 08:46 PM
ZygSpeed's Avatar
What else ... could an extended stud be for?
Ahhh ... nevermind.
Old Apr 25, 2004 | 10:04 PM
travis's Avatar
Default Re: purpose of extended wheel studs (zygspeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zygspeed &raquo;</TD></TR><TR><TD CLASS="quote">What else ... could an extended stud be for?
Ahhh ... nevermind. </TD></TR></TABLE>
What you do with your wheel studs is one of our business
Old Apr 26, 2004 | 01:34 AM
_BEN_'s Avatar
I dont remember the exact rule but the nhra requires that the studs go so far into the lugnuts. Or that they pass all of the way through the lug nuts. Something like that
Because when you run a wider rim with a different offset you need a longer stud depending on the brand of rim.
Old Apr 26, 2004 | 07:51 AM
MightyMouseTech's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gakkuken &raquo;</TD></TR><TR><TD CLASS="quote">can someone kindly explain the purpose of extended wheel studs?
thanks so much!</TD></TR></TABLE>
Well, for roadracing, it gives you a little more time before a wheel comes off, if it has not been tightened properly. After your car starts shaking violently (oops, wheel coming off) the extended studs may give you enough time to get back to the pits before the wheel comes completely off. MAY being the operative word.
Old Sep 1, 2004 | 09:24 PM
euclid's Avatar
Default Re: purpose of extended wheel studs (MightyMouseTech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MightyMouseTech &raquo;</TD></TR><TR><TD CLASS="quote">
Well, for roadracing, it gives you a little more time before a wheel comes off, if it has not been tightened properly. After your car starts shaking violently (oops, wheel coming off) the extended studs may give you enough time to get back to the pits before the wheel comes completely off. MAY being the operative word.</TD></TR></TABLE>
sorry to bring this back from the dead but in the event of the lugnuts loosening... they dont need to come off, once there is play the studs will just sheer off.
Old Sep 1, 2004 | 10:20 PM
oxycotton's Avatar
Default Re: purpose of extended wheel studs (euclid)
I want them just so I can be like those evil cartoon villians who have the knifes that come out of there hubs so they can attack everyone else's cars. I'm also working on the oil slick option too...
Old Sep 1, 2004 | 10:30 PM
Dr. EKology's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by euclid &raquo;</TD></TR><TR><TD CLASS="quote">
sorry to bring this back from the dead but in the event of the lugnuts loosening... they dont need to come off, once there is play the studs will just sheer off.</TD></TR></TABLE>
Got hobbies? Just messing with you man!
Old Sep 1, 2004 | 11:21 PM
oxycotton's Avatar
Default Re: purpose of extended wheel studs (EKology)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKology &raquo;</TD></TR><TR><TD CLASS="quote">
Got hobbies? </TD></TR></TABLE>
it is 1:21am...
Old Sep 2, 2004 | 07:42 AM
Knestis's Avatar
Default Re: purpose of extended wheel studs (oxycotton)
...and on a VW, they replace the gawd-awful wheel bolts that they come with.
This is with 5mm of spacer.
K
Old Sep 2, 2004 | 08:42 PM
euclid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Knestis &raquo;</TD></TR><TR><TD CLASS="quote">...and on a VW, they replace the gawd-awful wheel bolts that they come with.
bmws have those too must be good
Old Sep 3, 2004 | 06:29 AM
Driven's Avatar
K</TD></TR></TABLE>
VW and porsche should be shot for that design.
i hated that when i had my 914.
Old Sep 3, 2004 | 07:02 AM
fsp31's Avatar
Default Re: purpose of extended wheel studs (Driven)
The Aluminum hub on an RS Racing wheel is too thick for stock length Civic studs, even without spacers. Well, I guess you "could" use the stock studs, but I like the lug nuts to grab more than 2 or 3 threads...
Old Sep 3, 2004 | 11:30 AM
Driven's Avatar
to make you mad when you have to replace one... .grumbles: $5/ea and hub separation.
Old Jan 9, 2005 | 09:10 PM
93_hatch's Avatar
dont longer studs help with balancing the torque i not sure but i remember something like that on old school muscles they would put them on so they dont snap them
Old Jan 10, 2005 | 08:50 AM
Knestis's Avatar
Default Re: purpose of extended wheel studs (93_hatch)
No difference, if they are the same diameter and quality.
K
Old Jan 10, 2005 | 09:45 AM
Nate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Driven &raquo;</TD></TR><TR><TD CLASS="quote">
i hated that when i had my 914. </TD></TR></TABLE>
and early BMW's! no fun at all
Old Jan 10, 2005 | 09:51 AM
MattP's Avatar
Default Re: purpose of extended wheel studs (Nate)
I think the first BMW with lug bolts was the e21 3-series. I remember trying to convince the dealer I needed lugnuts for my 2002, and the parts guy wasn't having any of it - 'No BMW ever came with lugnuts!'
EDIT: And agreed, lugbolts = world of pain. I can't even imagine having to line up a rear drum and a wheel with lugbolts.
Old Jan 10, 2005 | 02:22 PM
SuzukaBlueAP2's Avatar
Default Re: purpose of extended wheel studs (MattP)
are there strength advantages/disadvantages to these extended wheel studs?
One may think that the longer studs would be weaker and more prone to snapping?
Just a thought...
Old Jan 10, 2005 | 02:28 PM
Willard's Avatar
Default Re: purpose of extended wheel studs (ScreaminTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScreaminTeg &raquo;</TD></TR><TR><TD CLASS="quote">are there strength advantages/disadvantages to these extended wheel studs?</TD></TR></TABLE>
most all aftermarket studs are stronger than OE studs.
disadvantage:
-takes longer to run the lugs on and off.
dc5RickK20
Jan 11, 2011 09:38 AM
ricehead
Nov 18, 2009 05:41 PM
Midori Green
15
Jan 1, 2008 10:39 PM
Mikey3000
Jan 12, 2006 07:05 AM
