JUN 3's with CTR Pistons...need some help
Old May 18, 2002 | 12:03 PM
RTW DC2R's Avatar
Default JUN 3's with CTR Pistons...need some help
Ive heard some people with ITR's run this setup with no problems, and others have valve clearance(I think thats what it is?) problems. How will I know if Im going to have a problem with that setup or not? I plan to use the stock ITR head gasket, or possibly going to a thinner one for added compression. But the thinner gasket will only make things that much more tight in the chamber and I dont know if it will be a problem or not. I know this is redundant, but any help is appreciated.
Old May 18, 2002 | 12:37 PM
MackSpeed-616's Avatar
Default Re: JUN 3's with CTR Pistons...need some help (RTW DC2)
you have nothing to worry about. ive been using ctr pistons, jun cams advanced to 4 degress and a head cut 40k with a stock gasket
Old May 18, 2002 | 02:15 PM
RTW DC2R's Avatar
Default Re: JUN 3's with CTR Pistons...need some help (Sexual Chocolate-616)
on an ITR motor?
Old May 18, 2002 | 03:02 PM
Chubz's Avatar
yes you'll be fine. If you really want to check your tolerences have the head clayed when you install the pistons (if they arent installed already). Im using the same setup
Old May 18, 2002 | 03:18 PM
on an ITR motor?
does it matter???
Old May 18, 2002 | 03:31 PM
RTW DC2R's Avatar
on an ITR motor?
does it matter???
I dont know, thats why Im asking!!
Old May 18, 2002 | 04:54 PM
acuracing's Avatar
You should be fine. Nothing to lose sleep over in your case.
Old May 18, 2002 | 05:05 PM
RTW DC2R's Avatar
Default Re: JUN 3's with CTR Pistons...need some help (acuracing)
what about with the thinner head gasket? too close for comfort?
Old May 18, 2002 | 05:09 PM
sgT's Avatar
sgT
616 over there had like .040" milled off his head and he had no contact
i wouldnt sweat a thinner head gasket, rather i would be more worried about
detonation than valve/piston contact.
Old May 18, 2002 | 08:17 PM
RTW DC2R's Avatar
Default Re: JUN 3's with CTR Pistons...need some help (sgT)
dont worry, I dont plan to take any top speed 150mph runs without getting the Hondata tuned first
JUNstageIII
Oct 26, 2008 09:35 AM
HamiltonRex
17
Feb 15, 2005 08:49 AM
Dohcvtec59
Oct 15, 2004 04:44 AM
infinkc
May 12, 2002 07:49 AM
905_S2K
Oct 20, 2001 06:15 AM
