has anyone done a b18c1 with itr rods and ctr pistons
my main concern is that the pistons will hit head, should i bore .25 over to clean up the cylinder walls and what gasket to run but what is still going to keep me at high compression
It will fit, but not by much. Boring over slightly is probably a bad idea. May I recommend not shaving the head any more than is absolutely necessary and make sure to clay the motor before final assembly and start up (buy an extra head gasket).
Re: (Kendall)
not that im an idiot but what does clay mean i was also thinking to run a 30 thous gasket is there a perticular gasket u would recomend and am i still going to be able to have a 13:1 compression my issue is that i have jun 3 cams and with my itrs i believe there isnt enough displacement you no what i mean another question i would like to add if poosible you can help me determine timing for those stage 3 cams so i can add to my chrome soft ware for temporary until i have it dynoed by king
HamiltonRex
17
02-15-2005 08:49 AM
