lx sedan/ ex coupe front brakes same?
Old Feb 6, 2007 | 07:31 AM
7808's Avatar
Default lx sedan/ ex coupe front brakes same?
are LX sedan and EX coupe front brakes the same? (both non-abs)
tried to search but it wouldnt include "lx"
Old Feb 6, 2007 | 08:12 AM
EL Vap133's Avatar
Default Re: lx sedan/ ex coupe front brakes same? (7808)
No, the EX has bigger brakes than the LX.
Old Feb 6, 2007 | 08:17 AM
philosofy1's Avatar
Default Re: lx sedan/ ex coupe front brakes same? (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">No, the EX has bigger brakes than the LX. </TD></TR></TABLE>
i thought they were the same. i thought dx, cx, hx were the smaller ones.
Old Feb 6, 2007 | 08:31 AM
7808's Avatar
are you sure? if so what parts do i swap, im gona be putting the engine and trans into the lx anyways
Old Feb 6, 2007 | 08:34 AM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 7808 &raquo;</TD></TR><TR><TD CLASS="quote">are you sure? if so what parts do i swap, im gona be putting the engine and trans into the lx anyways</TD></TR></TABLE>
if that's the case, then brakes have nothing to do with that. you can still use your lx front end brakes.
Old Feb 6, 2007 | 08:42 AM
7808's Avatar
Default Re: lx sedan/ ex coupe front brakes same? (philosofy1)
ya, but i want the larger brakes, i go through brakes fast as it is
Old Feb 6, 2007 | 08:46 AM
EL Vap133's Avatar
Yes I am sure, only the EX and Si had the front big brakes. Unless there is a special LX I didn't know about.
Old Feb 6, 2007 | 09:05 AM
Chim Chim's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 7808 &raquo;</TD></TR><TR><TD CLASS="quote">are LX sedan and EX coupe front brakes the same? (both non-abs)
tried to search but it wouldnt include "lx"</TD></TR></TABLE>
Only the LX sedan ABS automatic shared the same size brakes as the EX (10.3") as far as I know... You should visually be able to tell if they're the same comparing the caliper brakets and rotor size between the two...
EX caliper would look similar to this:
LX caliper would look something like this:
Since you're trying to put the best of everything into your sedan, take the EX brakes while you have everything out, since it's only one extra ball joint to pop on the UCA and a flare nut to remove the brake line...
The EX non-abs should come with a 7/8" MC while the LX non-abs should come with a 13/16" MC... If you're planning on doing rear discs in the future, you might want to look into a 15/16" MC from a 96-98 EX ABS (automatic)...
Old Feb 6, 2007 | 10:01 AM
BlueIntegraBoy's Avatar
Default Re: lx sedan/ ex coupe front brakes same? (Chim Chim)
^^ That's a very minty caliper, and a not so minty caliper.
Old Feb 6, 2007 | 10:22 AM
7808's Avatar
Default Re: lx sedan/ ex coupe front brakes same? (BlueIntegraBoy)
whats the MC
Old Feb 6, 2007 | 10:27 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 7808 &raquo;</TD></TR><TR><TD CLASS="quote">whats the MC</TD></TR></TABLE>
Master Cylinder
Old Feb 6, 2007 | 10:29 AM
EL Vap133's Avatar
What years did the LX come with ABS that it had bigger front brakes?
Old Feb 6, 2007 | 10:48 AM
Chim Chim's Avatar
It's pretty sporadic on Honda's part but the only one I can think of is the 96 LX...
It's like the rare stock equiped rear disc EX models...
Old Feb 6, 2007 | 10:54 AM
eg6sir-s's Avatar
1992-95 civic si (non abs) have 9.5' front brakes
1992-95 civic si (optional abs) have 10.3' front brakes
1992-95 civic lx sedan (non abs) have 9.5' front brakes
1992-95 civic lx sedan (optional abs) have 10.3' brakes
1992-95 civic ex (standard abs/optional abs) have 10.3' brakes
all other lower models 92-95 civic hatchback/coupe/sedan have 9.5' brakes.
10.3' brakes are the same size as 94-01 integra brakes (non-typeR models).
Old Feb 6, 2007 | 10:56 AM
EL Vap133's Avatar
Default Re: lx sedan/ ex coupe front brakes same? (eg6sir-s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6sir-s &raquo;</TD></TR><TR><TD CLASS="quote">
1992-95 civic lx sedan (optional abs) have 10.3' brakes</TD></TR></TABLE>
Ahh I see, I was thinking 96-00 but I didn't even think about 92-95.
Old Feb 6, 2007 | 11:27 AM
Chim Chim's Avatar
Slipped my mind as well since OP is working with a 6th gen coupe and sedan...
Old Feb 8, 2007 | 08:03 AM
7808's Avatar
ya i was talking about 96-00
so would i need to swap the Mc too?
Old Feb 8, 2007 | 09:42 PM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 7808 &raquo;</TD></TR><TR><TD CLASS="quote">ya i was talking about 96-00
so would i need to swap the Mc too?</TD></TR></TABLE>
Well in that case the LX brakes are smaller than the EX brakes. Yes you can use a 99-00 Si MC, the BB is the same as a DX so don't bother replacing it.
Old Feb 9, 2007 | 04:49 AM
7808's Avatar
why use the si mc not the ex ?
Old Feb 9, 2007 | 07:18 AM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 7808 &raquo;</TD></TR><TR><TD CLASS="quote">why use the si mc not the ex ? </TD></TR></TABLE>
My bad, does your current car have ABS? If yes then use EX MC, if not then use Si MC.
Old Feb 9, 2007 | 07:42 AM
7808's Avatar
niether have abs, i just want the larger ex coupe's front brakes on my lx sedan
both are 96
Old Feb 13, 2007 | 08:50 AM
7808's Avatar
up
Old Feb 13, 2007 | 08:52 AM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 7808 &raquo;</TD></TR><TR><TD CLASS="quote">niether have abs, i just want the larger ex coupe's front brakes on my lx sedan
both are 96</TD></TR></TABLE>
Well since your car did not come with ABS, you should go with the Si MC since it did not come with ABS either.
Old Feb 14, 2007 | 09:08 AM
7808's Avatar
sorry if im sounding retarded.. but i dont get it. none of them have abs, whats the differnce in mc's? and why cant i use my lx's no abs mc with the ex's no abs front brakes?
Old Feb 14, 2007 | 10:39 AM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 7808 &raquo;</TD></TR><TR><TD CLASS="quote">sorry if im sounding retarded.. but i dont get it. none of them have abs, whats the differnce in mc's? and why cant i use my lx's no abs mc with the ex's no abs front brakes? </TD></TR></TABLE>
You can keep your stock one if you want. The problem with using a MC from a vehicle that had ABS are getting the brake lines to fit onto the MC. You either have to make your own lines or bend them to get them to fit.
I was simply suggesting that if you wanted to upgrade the MC, you can easily do so with an Si (EM1) MC.
quetzalcoatl
Oct 3, 2008 09:42 PM
Mr.Speed
Sep 22, 2008 02:33 PM
ej6joe
27
Feb 17, 2008 05:10 PM
sony224422
Nov 26, 2005 07:04 PM
spock_rocker
Jul 30, 2004 11:05 PM
