Question about the IAC valve....
Old May 18, 2002 | 05:49 AM
allmotor2000's Avatar
Default Question about the IAC valve....
the other day my friend got the CEL code 14 and its the IAC valve like mine. is car gets itthe smae way idid. He replaced itbut it still does it. Has anyone fixed their IAC valve problem? when he starts his car...the RPM goes up to about 2000 and then comes down after 3 seconds....is this normal for it to do that? mine is doing the same thing...wat could be the problem?? also i drive normal but my idle is at like 1000 rpm....is that normal??
Old May 18, 2002 | 06:08 AM
M.A.R.C.'s Avatar
Default Re: Question about the IAC valve.... (allmotor2000)
Welcome to the club. I've had my problems since January. Replaced the IACV, no help. Took it back to the dealership they turned me back saying I voided the warranty (they somehow found out I HAD nitrous in the car... 8 months ago). I'm going to try a new throttle body and TPS soon. The dealership said my throttle plate was bent anyway, and my TPS voltage is a little off.
Old May 18, 2002 | 02:01 PM
MrFatBooty's Avatar
Could be your fast idle thermo valve. Normally it doesn't trigger a CEL but hey, it's worth a shot.
Otherwise, you sure that all the vacuum and coolant lines going to the IACV are hooked up correctly?
Old May 18, 2002 | 02:09 PM
B18C-RnVA's Avatar
New User
Default Re: Question about the IAC valve.... (MrFatBooty)
i give up on taht ****..lol
Old May 18, 2002 | 02:11 PM
3rdGteg's Avatar
Check all your vacuum and fuel lines. Try playing with the idle screw on the throttle body and see if you can pull the idle down a little. I had that same problem awhile back and it took me like 5-6 months to finally fix it; but I can't really remember what I did cuz I had too many problems since then one after the other nonstop. Good Luck with it.
Old May 18, 2002 | 09:38 PM
Default Re: Question about the IAC valve.... (3rdGteg)
damn man !!! its buggin me so much!!! help me!! okay about checking the vaccum lines...which lines are they? my car freaking idles atlike 1300 sometimes...where is the stock idle at? help please...wats the tps....where is it at wat do i do to it?
Old May 18, 2002 | 11:12 PM
speedillusion's Avatar
New User
IMO. i'd check my t/b cable also. set it to where you'd want a good idle, whatever you prefer. below 2k
Old May 18, 2002 | 11:24 PM
M.A.R.C.'s Avatar
Default Re: Question about the IAC valve.... (midnitekreeper)
I personally have checked everything so far. I think it's the throttle cable though. It was kinda tight. Might have been too tight and bent the throttle off axis or something. Gonna try a new throttle body soon.
Old May 19, 2002 | 06:01 AM
Default Re: Question about the IAC valve.... (CivicRyda2k)
i've tried adjusting the throttle cable and it didnt do anything. didnt really idle any lower. to adjust it you just turn those two lil nuts and adjust the cable to give it slack or to give it tension right?
Old May 19, 2002 | 06:05 AM
another question for you guys....when you start your car...what happens to the rpms? does it go high for a bit and then fall to like about idle....im not talking about from a cold start...lets say your car is all warmmed up and you go get something to eat...at a restaurant...you come out and you start it after....does the rpm stay at 2-3 for about 2 seconds and then drop? or does it drop right away?
Old May 19, 2002 | 06:07 AM
B18C-RnVA's Avatar
New User
my car is doing the opposite of you guys...my car idles to low. and throws codes and **** isnt wrong. im all confused. my car stalls out unless when im riding i have to bring the RPMs down slow.
Old May 19, 2002 | 06:39 AM
Default Re: Question about the IAC valve.... (B18C-RnVA)
i think urs would just be the idle cable positioning...try to set it so that it idles at the right idleing rpm. i think its about 7-8 or maybe even 9...please someone help.
Old May 19, 2002 | 09:13 AM
B18C-RnVA's Avatar
New User
the idle postioning sensor, how do you adjust that??
Old May 20, 2002 | 07:16 AM
New User
are you getting this reading off an autometer tach? just curious?
Old May 20, 2002 | 07:35 AM
if you're not getting this off an autometer tach then you should adjust it. You can adjust the throttle cable and see if it does anything. If that does not do anything you can adust the lil screw that is right on top of the throttle body itself. you have to use a flathead screwdriveer to do this. Just open your hood...go to the right of your car...and then look at your throttle body. you should see that little screw...turn it in to make the idle lower and turn it counter clock wise to make the throttle higher.
Luca
Sep 21, 2010 11:24 AM
jdmboy
Sep 6, 2005 03:30 PM
Ricey McRicerton
Mar 19, 2004 09:11 AM
