Cat heat sensor light on JDM gauges
Old Feb 5, 2007 | 09:01 AM
xivsavagevix's Avatar
Default Cat heat sensor light on JDM gauges
I did a search to see if other people were having this problem, but no luck.
So my catalytic converter heat sensor light stays lit on my 96 spec itr gauges (on my 94 DC). You guys think it's staying lit because it is not getting a signal from a heat sensor?
I know people are doing the green-film-switch or the gauges-switch method, but I did a pinout instead to keep everything "intact." But apparently I don't have to do a pinout for the cat sensor because we don't have one.
Bottom line: You guys think the gauges are made for the heat sensor light to stay lit if it's NOT getting a signal?
Old Feb 5, 2007 | 07:17 PM
BlueIntegraBoy's Avatar
Default Re: Cat heat sensor light on JDM gauges (xivsavagevix)
As long as your other components of your cluster are working, then just pull the bulb. You don't need it staring at you.
ccibai
Feb 8, 2008 07:44 AM
Euro-r
Oct 8, 2007 11:03 AM
miahjera04
Aug 3, 2006 04:45 PM
tthomass
Jun 15, 2006 09:14 AM
jdm_DC2R
Mar 14, 2006 09:16 AM
