Shift-linkage roll pin.
Old Feb 5, 2007 | 04:52 AM
JShull's Avatar
Default Shift-linkage roll pin.
I'm having one hell of a time removing it this time. A friend of mine put it in las time while I was grabbing a bite to eat (his car at the time) and mushroomed the it going in from the bottom. I ground the pin down so I could take the linkage off and pull the motor (no biggie I thought, shiftlikage was rusty and ragged anyhow) I have the tranny off of the motor now and the pin is still stuck. I haven't tried heating it, but its next on my list. My question is do you guys have any ideas?
Crappy pics of roll pin.
Can I grind the verticle pin and then put a bolt through that part with a new linkage?
Old Feb 5, 2007 | 04:59 AM
B18CivicEH2's Avatar
Default Re: Shift-linkage roll pin. (JShull)
i usually use a screwdriver to push it out....but i heard from others that a punch works wonders....get a rubber mallet and seach for the correct size punch and go purchase it......
Old Feb 5, 2007 | 05:03 AM
JDM_dreamer's Avatar
Default Re: Shift-linkage roll pin. (B18CivicEg)
if you have the tranny off, knock it out from the top instead of the bottom. use a punch though, it makes it 10x easer (though it still sucks to do)
Old Feb 5, 2007 | 05:17 AM
JShull's Avatar
I'm going to pick up a punch set with the correct size punch today. The screwdriver method from the top didn't work for me yesterday.
Another question. Rubber mallet, deadblow, 2lb hammer. Which whould be better to use?
Old Feb 5, 2007 | 05:37 AM
Luserkid's Avatar
Default Re: (JShull)
Any 8mm bolt will knock that out or you could pick up the tool that sp and matco makes.
http://www.matcotools.com/Cata...57038
Old Feb 5, 2007 | 05:46 AM
JShull's Avatar
Thanks for the tip on the 8mm bolt. When I head to school I am going to pick up an extra long one so I will have room to hit it and not hit the tranny casing.
Old Feb 5, 2007 | 06:29 AM
evilsolb16's Avatar
just take a 1/4in extension and grind it so that it is a little skinnier thats what i use.
Old Feb 5, 2007 | 08:48 AM
2wheelhunter's Avatar
Default Re: (evilsolb16)
air chisle and a skinny blunt object (8mm bolt)
Old Feb 5, 2007 | 10:27 AM
Big Teggie's Avatar
Pin punch and a hammer. Yea, its really that simple.
Old Feb 5, 2007 | 10:59 AM
dad0c402's Avatar
This might sound a little extreme but it mine was really stuck and space was limited. A punch works perfect to put it in but getting it to stay on the spot is tricky. I took a long philips screwdriver that was the perfect size, the tip helped to hold it in. Stuck the screwdriver on top of my axle nut socket and aligned that under the car on the pin. Slowly lowered my car and "ping" (yea it really made that sound) it popped out. Just gotta listen to were it lands to find it.
If i'm hearing right then you already have out and in that case a more commonly found screwdriver might help keep it align while you whack the hell out of it.
speedjunkie_g35
29
Aug 20, 2023 09:42 AM
dr_latino999
25
Jan 9, 2023 06:47 PM
Poootie
Aug 14, 2013 04:23 PM
Corksil
12
Dec 29, 2009 10:14 PM
EKsite
Honda Motorcycles
15
Apr 26, 2007 04:15 PM
