bore b16 to 1.8
Old Feb 4, 2007 | 04:04 PM
b16a4's Avatar
Default bore b16 to 1.8
What do you guys think about boring out a b16 to a 1.8?
How is this done?
Is This safe?
Old Feb 4, 2007 | 04:41 PM
Brick Top's Avatar
Default Re: bore b16 to 1.8 (b16a4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16a4 &raquo;</TD></TR><TR><TD CLASS="quote">What do you guys think about boring out a b16 to a 1.8?
How is this done?
Is This safe?</TD></TR></TABLE>
you can have it re-sleeved with stronger ones at the bore you want. safest way. or just get a 1.8 block.
Old Feb 4, 2007 | 11:52 PM
ExospeedAMcrx's Avatar
right... would have to Sleeve the block then bored out to 86mm to make it a 1.8L
Easier to use a 1.8L (LS, GSR or ITR) block to start off with to get the displacement without having to go big on the bore.
Old Feb 5, 2007 | 12:39 AM
integrainside's Avatar
A 1.8L GSR is only an 81mm, B20 is an 84mm.... where did the 86mm come from?
Anyways, if you want to bore a B16 that much i would highly recomend getting it sleeved. Nothing but good things from the Golden Eagle HD sleeves.
Old Feb 5, 2007 | 12:43 AM
Default Re: (integrainside)
he's using a b16. for a b16 takes bigger bore to make a 1.8L out of a 77mm crank.
Its not the same bore size calculations for the B18 and B20. The calculations from those blocks on the bore size are similar since their stroke is similar. the B16 is way off.
b16a4
Feb 4, 2007 05:30 PM
MKcrxB16
25
Jul 20, 2006 11:36 AM
SpdFrk
Aug 29, 2003 07:42 AM
B16 BROTHER
Jun 19, 2003 10:18 AM
sleepercivic
Oct 22, 2002 07:37 AM
