Big bore b16
Old Jun 16, 2003 | 06:20 PM
B16 BROTHER's Avatar
Default Big bore b16
Who here has a b16 that is sleeved by golden eagle that has a bore over 81mm. If so how do u like it and what kind of power are u putting out?
Old Jun 16, 2003 | 06:30 PM
Boostfed's Avatar
New User
Default Re: Big bore b16 (B16 BROTHER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16 BROTHER &raquo;</TD></TR><TR><TD CLASS="quote">Who here has a b16 that is sleeved by golden eagle that has a bore over 81mm. If so how do u like it and what kind of power are u putting out?</TD></TR></TABLE>
Yeah I had a B16A block bored to 84.5 By GE, they had the piston to wall clearance really loose adn then the sleeves sunk. I sent it back and they "fixed it" , uh no I got it all back together went 85mm since the bores were too big and they sunk again, car was on the dyno 14psi 370whp, pressurized coolant into the reservoir. They all sunk again .003 below the deck, before they were .001 below the deck for #1 and #4 and even on #2 and #3, before that build they were stepped .003 above the deck. This is my experience with GE, others have had great success though. I have a Darton sleeved block now and am hoping for the best. At least I got my refund from GE! I am still out of a lot of money and time but so life goes. Good luck.
Old Jun 16, 2003 | 06:39 PM
You_Get_Vapors
Guest
Posts: n/a
Default Re: Big bore b16 (Boostfed)
What bore is the darton? Hows it holding up? What are the hp figures? Stock stroke and rod length? Please do tell....
Old Jun 16, 2003 | 06:56 PM
Boostfed's Avatar
New User
Default Re: Big bore b16 (You_Get_Vapors)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by You_Get_Vapors &raquo;</TD></TR><TR><TD CLASS="quote">What bore is the darton? Hows it holding up? What are the hp figures? Stock stroke and rod length? Please do tell....</TD></TR></TABLE>
I picked up the block from a friend and he had it bored and honed already for a set of JE Pistons 84mm so I went with them that way if I ever rebuild I have room to go to 84.5 and I still have my 85mm Endyn pistons too. Stock stroke. We will see how the motor does in a week or two, it's all put together minus the cams and timing belt right now. I will post results as soon as I have some, dyno #s and 1/4 times.
Old Jun 16, 2003 | 07:32 PM
Thank you for all of your replies I was thinking of going 83mm with a sc61 turbo do u guys think this will be a good combo?
Old Jun 16, 2003 | 07:57 PM
Boostfed's Avatar
New User
Default Re: (B16 BROTHER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16 BROTHER &raquo;</TD></TR><TR><TD CLASS="quote">Thank you for all of your replies I was thinking of going 83mm with a sc61 turbo do u guys think this will be a good combo?</TD></TR></TABLE>
and go through Art for the Precision SC61, he will take care of you!
Old Jun 16, 2003 | 07:59 PM
You_Get_Vapors
Guest
Posts: n/a
Cool keep me updated. I was thinking of going with a 84mm bore if i decide to sleeve my block. Most likely with Dartons or AEBS. Thanx
Old Jun 16, 2003 | 08:02 PM
Yea I talked to art the other day on the phone really cool guy. He is going to help me on my purchase thanks!
Old Jun 16, 2003 | 08:05 PM
Boostfed's Avatar
New User
What are your goals actually? I made 370whp and 273ft-lb torque with a small T3/T04B turbo that came with my DRAG kit 81.5mm bore stock sleeves. When I went to 84.5mm bore I made the same power with 14psi and at 25psi I made 500whp 333 ft-lb torque. So here some #s for you to crunch. Good luck!
Old Jun 16, 2003 | 08:10 PM
I am looking for about 400 to the wheels on pump gas. If that is not possible I am looking for as clos to that as I can get off the pump. Just some more info I am building my car more for a 45 or a 60 puch I like those rolling starts.
Old Jun 17, 2003 | 11:10 AM
TURBO B's Avatar
bump
Old Jun 17, 2003 | 11:48 AM
alpha's Avatar
My B16a block was resleeved, honed, bored, etc. by Golden Eagle. I had them bore it to 84mm. No dyno numbers yet but one day this year I might have some, lol.
http://photos.yahoo.com/bc/alp...iew=t
Old Jun 18, 2003 | 07:19 AM
granada_sun's Avatar
what pistons did you use for 84mm bore?
Old Jun 18, 2003 | 07:41 AM
alpha's Avatar
Default Re: (granada_sun)
I used ENDYN pistons.
Old Jun 18, 2003 | 08:09 AM
nice pistons.....where'd u get em?
Old Jun 18, 2003 | 08:29 AM
alpha's Avatar
Thanks. I got them from Golden Eagle while my block was there being resleeved.
Old Jun 18, 2003 | 09:56 AM
cool, im assuming it was resleeved for reinforcement right? i called up a local machine shop and they said resleeving wasn't really necessary?? I had to wonder about high revving, high boost engine though.....
Old Jun 18, 2003 | 10:00 AM
teamrocket si's Avatar
I'm also building a 84 mm b16, sleeved by RS machine. It will be up in running in the next month or so. I hope
alpha's Avatar
I resleeved my block because I am going to be pushing 400+whp (my goal is 475whp). If I were shooting for 350whp I wouldn't of resleeved my block.
Old Jun 18, 2003 | 10:27 AM
Screamer's Avatar
Boostfed What was the original psi that you hit the 370whp on??? You mentioned 14psi on 84.5 bore, but what psi at 81.5 bore ???.
Thanks.
Old Jun 18, 2003 | 10:43 AM
Scott - 93HB Si's Avatar
Default Re: Big bore b16 (Screamer)
I was running 84mm on a Lienter Sleeved B16A block with T-top sleeves....It cracked right down the number 3 cylinder with less than 50 miles on the block!! I suspect the sleeves were the culprit. Going with Dartons this next time.
Old Jun 18, 2003 | 11:01 AM
alpha's Avatar
Default Re: Big bore b16 (Scott - 93HB Si)
That's too bad. Those sleeves looked good
Old Jun 18, 2003 | 11:15 AM
Kataku2K3's Avatar
Default Re: Big bore b16 (0x64)
This is Will's GE sleeved 86mm 1.79L B16A which is going in his Rex... It's just another boosted motor and it should make ~400-450whp... Who knows, he just wishes he would have gone with a B18C now like Brian, Duc, and Kenny Oh well, it's in a Rex, should go pretty good... Good Luck
Old Jun 18, 2003 | 11:24 AM
alpha's Avatar
Default Re: Big bore b16 (Kataku2K3)
That much power in a CRX is crazy
Old Jun 18, 2003 | 11:33 AM
Nice Clutch!
86mm boosted, eh? Gotta love 1 piece sleeves! :D
