Fouled Plugs!!
Old May 17, 2002 | 07:59 PM
Alpha_GSR's Avatar
Default Fouled Plugs!!
Hey guys, yesterday I pulled out my spark plugs and found that there were all covered with a dark black soot. I replaced all of them, and check today to find out they all look the same again.
I'm not sure what could be causing this problem, have any of you guys had a similar problem? Thanks in advance.
Kong
Old May 17, 2002 | 09:00 PM
acuracing's Avatar
Default Re: Fouled Plugs!! (Alpha_GSR)
What kind of plugs are they? Did you gap them correctly? I'm assuming from your name that you have a GSR...
Old May 17, 2002 | 09:29 PM
Alpha_GSR's Avatar
Default Re: Fouled Plugs!! (acuracing)
I've been using Bosch Platinums +2, and +4. To my knowledge, they come pregapped.
Old May 17, 2002 | 11:08 PM
90civichbsi's Avatar
dont go w/ bosch +4s on a honda, they run too hot, you dont want to warp the head. they work great on mustangs and stuff, but not so good on hondas
Old May 18, 2002 | 02:31 AM
88_SC_CRX_Si's Avatar
New User
Might take a look at your fuel pressure regulator. Could be going bad, and allowing to much pressure to build, causing a rich condition. Otherwise, could be rings or valves seals, or a little of both...
[Modified by 88_SC_CRX_Si, 3:33 AM 5/18/2002]
Old May 18, 2002 | 06:14 AM
SolidSpruce's Avatar
Default Re: Fouled Plugs!! (88_SC_CRX_Si)
speaking of plugs - which are good plugs for honda's? i used to use those bosch platinum 4+ too.........but someone told me the same thing - the run too hot! so i switched to the new split fires iridium , anyways, what do u guys use?
im also running boost - so im looking for a good 'cold' plug...
Old May 18, 2002 | 07:05 AM
Default Re: Fouled Plugs!! (SolidSpruce)
some of the best pulgs are the denso iridiums, thye can run ya 50 bucks for a set but they work well
Old May 18, 2002 | 12:13 PM
Jared's Avatar
Default Re: Fouled Plugs!! (90civichbsi)
I really don't like the Bosch +2 and +4 plugs. I'm not convinced that they work well at all. I'm using regular Bosch platinums in my turbo car, and factory NGKs in my other cars. What kind of setup are you running? and what part is covered in black soot? the porcelain or the base?
Old May 18, 2002 | 05:50 PM
Alpha_GSR's Avatar
Default Re: Fouled Plugs!! (Teken)
Thanks a lot guys, you've been a big help!!
The whole entir plug is covered in a dry dark black powder.
My setup is a fully built high compression LS/Vtec runing Hondata built by IB.
I was running rich, and Jeff recently sent me another chip to plug into my ECU to solve that problem The day after I plugged in the chip, is when I noticed the change in my plugs. I'm thinking that's the problem of my car alongside a weak ignition system.
I'm considering buying some MSD stuff, and then retuning my car at IB. What do you guys think is a fair price to tune my car?? I built it there and tuned it there so I wouldn't have any problems, but life's never perfect. My car's been running rich eversince I got it back.
Kong
Old May 20, 2002 | 05:43 AM
New User
I would just stick with OEM... Honda's ignition are really above the "others" out there. Going with MSD, etc... just more for eye candy, unless you are going to be boosting outrages amounts, or a super high C/R....
StockAccord
12
Aug 24, 2009 09:53 AM
turbo boost
Mar 4, 2005 07:03 AM
BlueShadow
Jan 29, 2003 10:01 AM
pub
Dec 21, 2002 03:50 PM
forcedaccord95
Aug 7, 2002 11:41 AM
