Colder Plugs?
Old Aug 3, 2002 | 05:05 PM
forcedaccord95's Avatar
Default Colder Plugs?
I recently was told to run these plugs. They are NGK BKR7E-11, ever since I put these plugs in, my car sound like it is missing. The needle on my rpm guage stays still, but it makes this spuddering noise(very quiet) out of my exhaust. I was told by others to step up, one spark plug colder, is this a good idea and does anyone now what the model number is?My fuel pressure is @ around 50lbs, so I think this is good, please let me know!
[Modified by forcedaccord95, 2:06 AM 8/4/2002]
Old Aug 3, 2002 | 05:43 PM
echo999's Avatar
New User
Default Re: Colder Plugs? (forcedaccord95)
My problem exactly..
I tried gapping at .22, .25, .28, .30, and .35 and it still misses..
It didn't miss with the stock plugs.. and didn't miss when I put the stock ones
back in..
Old Aug 3, 2002 | 06:08 PM
ekb18c's Avatar
Bkr7e-11 are good plugs. Try to gap them at .30-.032. Your fuel pressure is kinda high, what is your fuel setup? Do you have an aftermarket ignition system(MSD)?
Old Aug 3, 2002 | 09:37 PM
bmm89's Avatar
Default Re: Colder Plugs? (ekb18c)
I have same plugs and have them gapped inititally at .026 now .032, no problems at either nor with stock... but then again i have an upgraded ignition, external coil, i would check your spark plug wires.
Old Aug 3, 2002 | 10:11 PM
turbosol's Avatar
Default Re: Colder Plugs? (bmm89)
What heat range did your car come with originally? 5 or 6 If it was a 5 your may have gotten too cold of a plug. That being the case your plug wouldn't get up to temp and would foul causing the misses.
Old Aug 6, 2002 | 07:22 PM
Default Re: Colder Plugs? (turbosol)
I pulled out the plugs today, they were a grayish almost white after 3-4 days, lean right?
Old Aug 6, 2002 | 11:26 PM
TriK's Avatar
yop... white color on spark plug it's because your running lean
Old Aug 7, 2002 | 01:30 AM
quickspoolin's Avatar
You just barely put those plugs in so I don't think the reading would be accurate. Whenever I put in new plugs I have to put some miles on them to get that golden brown color to even show.
Old Aug 7, 2002 | 01:40 AM
blkDOHCsol's Avatar
New User
Default Re: Colder Plugs? (quickspoolin)
why are you running colder? turbo?
Old Aug 7, 2002 | 07:46 AM
Default Re: Colder Plugs? (blkDOHCsol)
the thing is, my regulator is messed up and my fuel will not go below 60lbs, I know this is why my car is running like ****, I just found this out the other day, sure the plugs are good for my application, but why are my plugs lean with that much fuel?
Old Aug 7, 2002 | 10:17 AM
lucas569's Avatar
whats your fuel set up? inline, intank? fmu? larger injectors?
i had this sam eproblem this week and it seems the closer i gappped the plugs to stock setting (.44) the BETTER the car ran, i'm at .40 at the moment, w/ 43 psi base fuel pressure but this is w/ Rc 440cc injectors.
Old Aug 7, 2002 | 11:19 AM
KiddEng's Avatar
Default Re: Colder Plugs? (lucas569)
maybe u guys can help me out, i just put in the greddy turbo into d16y5, and for some reason when im in neutral or in gear i can't rev past 4k after a few mins of driving the car. my stock heat range is a 4, but i gotten 5 for the time being and gapped at .044.
when the tach gets up to 4k it will feel like it hit a rev limiter and bounce off it and cant go any farther... i know my fuel is running rich and i tried leaning out but the problem still comes back. my fuel set up is: 280cc injectors, 12:1 fmu, b&m reg.,walbro 255, vafc... is my ignition system too weak to spark after 4k cause thats when boost builds?
thanks in advance
-terry
Old Aug 7, 2002 | 11:41 AM
shadowdawn's Avatar
Default Re: Colder Plugs? (KiddEng)
Mine are gapped at .030 and I also hear this REAL suttle like pop/hesitating sound at idle.... I mean its barely noticable but I can tell, does this when the car is first started, warming up, and idling after already warming up.... does this mean I'm miss firing also?
[edit] Oh yea I have the same BK 2 steps colder plugs
[Modified by shadowdawn, 3:41 PM 8/7/2002]
Frank_2.0L
Jul 30, 2007 11:08 PM
Smokey5176
May 8, 2007 05:01 PM
scarecrow
Jun 4, 2006 01:08 PM
skierGT
Jun 17, 2003 05:06 AM
Babalouie
Jun 24, 2001 07:33 PM
