Cooling system problem?
Well I have a interesting problem with my daily beater ef, I can let it warm up and the temp gauge will go up to about normal but as soon as I start driving it drops to the bottom? any ideas? It wouldnt bother me so much if it was summer but its 12 degrees out when I drive to work and my heater feels like ac
I'll pull the thermostat and check it, the upper hose has pressure but I never checked the lower. the fan is wired normally it only comes on when the switch turns it on. thanks for the help guys
Anything else I should check?
I checked the upper and lower hose they both get hot but no pressure I can squeeze em with my hand no problem. Havent had time to pulll the thermostat yet. And yes there is plenty of antifreeze and hardly any water.
Nocturnal
Feb 22, 2004 08:48 AM
DRKSol
Jul 6, 2003 02:59 PM
