Wheel Bearing replacement
Old May 17, 2002 | 01:01 PM
Dawsonb17a's Avatar
New User
Default Wheel Bearing replacement
Okay, so I just found out that really annoying sound that my car makes when it moves is being caused by wheel bearings, as I friend of mine pointed it out.
He said it isn't a very hard job to do, so I'm thinking that I'll attempt to replace the bearings myself. I have the factory service manual (but haven't looked into it yet as I'm away from it till Monday) and a friend's 20 ton hydraulic press at my disposal for pressing them in. I've never removed the hub before, but I have removed everything up to the hub to replace some studs.
Is this an easy and straightforward job is what I want to know.
[Modified by Dawsonb17a, 5:02 PM 5/17/2002]
[Modified by Dawsonb17a, 5:03 PM 5/17/2002]
Old May 17, 2002 | 01:15 PM
SEFIxCivic's Avatar
Default Re: Wheel Bearing replacement (Dawsonb17a)
I wouldnt totally say its straight forward. you got to make sure when using the press you have the proper fixtures to prevent damage to your new bearing. only push on the outside race. a little bit hard to explain in words, but i hope you understand what im saying.
Old May 17, 2002 | 09:14 PM
TodaSi's Avatar
Default Re: Wheel Bearing replacement (SEFI8LOxCivic)
A lot of people heat up the knuckle in their oven to about 250-275 degrees, and then freeze the bearing. The bearing is supposed to just slide in, simple. I haven't tried this yet but plan to.
Chad: who wishes there was a pictorial on how to replace bearings and wheel studs because I have to do it
Old May 17, 2002 | 10:09 PM
SEFIxCivic's Avatar
Default Re: Wheel Bearing replacement (TodaSi)
using just the plain press works pretty good. just a little bit time consuming.
rexload
Jun 5, 2015 11:31 AM
DK-EK9
Sep 27, 2012 06:12 AM
FakeJDMEF8
18
Nov 22, 2005 08:13 PM
buzlink
Jul 18, 2002 06:44 PM
Cow
May 2, 2002 05:42 PM
