Vac. box question. Do I need a aftermarket?
Old Jan 31, 2007 | 02:57 PM
THE GUY's Avatar
Not to be confused with "THE MAN"
Default Vac. box question. Do I need a aftermarket?
Ok here is the deal. I am putting together my LS-VTEC and I ran into a little hangup. On the back of the block where the vac. box goes in my LS the hole into the block does not go through.
But in my GSR block it does go through to the crank case.
Does this mean I am going to have to run a endyne or other vac. canister?
None of my other LS blocks have been closed off like this. BTW it is a B18B block.
Thanks guys.
Old Jan 31, 2007 | 03:09 PM
Luserkid's Avatar
Default Re: Vac. box question. Do I need a aftermarket? (THE GUY)
Someone might have sealed that hole. It should have been opened. Anyway its better to run aftermarket cans with the block vent holes instead of that pcv system it has.
Old Jan 31, 2007 | 03:38 PM
THE GUY's Avatar
That's what I was thinking, but its not plugged. It Is in the casting. But thanks bro, I guess I'll be buyin one tonight.
Old Jan 31, 2007 | 04:26 PM
EMoneR's Avatar
Default Re: (THE GUY)
i just ran into the same problem. Im just doing like what he said
Sambo_Eddo
May 3, 2010 07:13 PM
lambertincorp
Jan 24, 2010 10:28 AM
revolt_allmotor
Mar 23, 2005 03:24 PM
2000Accord5sp
Feb 13, 2002 11:31 AM
