power window
From: down the street,bythe river in the van, co, united states
so my window on my si stopped rolling up like 3 weeks ago it used to work then all of a sudden it stoped working i checked the fuses and the door harness is pluged in wat do u guys think is wrong with it/ wat should i do any suggestions on wat could be wrong o wat can i do so it can start working again o advice on where to take it to get it fixed thanks
dumb question, but is it just off the track? sometimes, as in with my 98 civic, the window kept coming off the track, or if it didnt come all the way off, would just get stuck in the rubber molding. so maybe there is something there?
does the motor make any noise at all like it's actually trying to put the window up and down???
if not then it's a power feed problem double check all fuses and plugs.
check fuses with a meter...not by eye!!!
set a digital multimeter to continuity and test all fuses
nope its on the right path where the window should go i even put wd40 to see if maybe a lil bit of lubrication can help out but nope it didint help wat u guys think i should do where should i take my car to get it checked out
my passanger side window stopped working after I took the car in to get new tint put on. I went back after my 5 days of waiting to roll the windows down and he said hey I didn't do ****. There is no noise coming from the motor. I checked the wires to the switch and they are contected on both doors. I don't know wtf he did.
