power window electrical problem??
Old Jan 9, 2009 | 12:05 PM
JDM SIR-G's Avatar
Icon2 power window electrical problem??
In my 99 civic the driver side power window does not want to roll down. the passanger side works fine, i thought it was the motor but it did not work then it started to work again but now it just doesnt want to roll down, i dont really know much about electrical but i check the fuse and thats ok, and also i checked the switch and nothing seems to be wrong with those, before i take it in to get looked at i just wanted to know what you guys think the problem might be.
thanks
Old Jan 9, 2009 | 01:21 PM
TunerN00b's Avatar
Default Re: power window electrical problem??
Dirt in the track has kept my DC2's power window from working at times. Cleaning the track fixed it.
Though, I have also had my switch short out, destroying the wiring, motor, and regulator in the process, but I have been dumb enough to have the window open in the rain and I know the switch got wet (autocross in the rain).
Old Jan 9, 2009 | 04:27 PM
Evs-One's Avatar
Solbros Owns Me
It's really common for the wires in the harness to break at the hinge- from years of opening the door, etc. First symptom of this is usually the window not working
Get yourself an ETM and start tracing wires!
Old Jan 10, 2009 | 10:58 AM
fcm's Avatar
fcm
Old Fart
Originally Posted by JDM SIR-G
In my 99 civic the driver side power window . the passanger side works fine, i thought it was the motor but it did not work then it started to work again but now it just doesnt want to roll down, i dont really know much about electrical but i check the fuse and thats ok, and also i checked the switch and nothing seems to be wrong with those, before i take it in to get looked at i just wanted to know what you guys think the problem might be.
thanks
When you say " does not want to roll down" does that mean if you flick the switch to up it will move a little, [meaning up is working but down is not]?
If so the problem is the switch, it could be just dirty/burnt contacts or the "Auto Down" module.
I would check the switch first. 94
reemer
Nov 29, 2008 08:16 AM
99hondacura
Feb 6, 2007 06:54 PM
Ej1_coupe
May 29, 2006 06:39 PM
Duck Sauce
Jan 29, 2002 11:27 AM
