Car stuttering at low rpms, good idle...ignition module???
idles fine once i start moving stutters from about 1100 rpm to 2500 rpm then goes away car runs fine...what the hell? plugs and wires are fine and its getting fuel...could it be the ignition module any one ever had similar syptoms? this a b16a2 obd-2 distributor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D.Dappa »</TD></TR><TR><TD CLASS="quote">idles fine once i start moving stutters from about 1100 rpm to 2500 rpm then goes away car runs fine...what the hell? plugs and wires are fine and its getting fuel...could it be the ignition module any one ever had similar syptoms? this a b16a2 obd-2 distributor.</TD></TR></TABLE>
Now what do you mean exactly by "the plugs and wires are fine."
As in you changed them and it's still doing it? Or as in they look fine?
'Cause it sounds like your wires.
EDIT:
PS: Yeah, I had similar symptoms, it was my wires.
EDIT:
mine did the samee ****!! all in second gear and after fine and also at idle fine.. i got brand new spark
plugs, wires, cap &rotor and she runs awsome..like it never studdered...!
y<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate »</TD></TR><TR><TD CLASS="quote">Did you change the rotor and cap as well?</TD></TR></TABLE>
yep changed that as well
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D.Dappa »</TD></TR><TR><TD CLASS="quote">y
yep changed that as well</TD></TR></TABLE>
the one thing that i have found to do this and is the one thing that people tend to over look is the pcv valve. it is only like $3, change it out and see what happens.
track_assassin
Apr 23, 2006 04:53 PM
