my spedo's gone crazy
ok so just today my spedo started acting all crazy sometimes when im driving it doesnt even move just stays at zero then sometimes it jumps up and down or sometimes itll shoot up to 60 when im goin no more then 30 and sometimes when im at a dead stop itll jump up a little. no cel. any ideas? vss or spedo problem?
check your connection at the vss, i had the same thing happen and ended cleaning the connector because it had too much resistance and only worked when i drove through water
so check that connector first!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96civb18c1 »</TD></TR><TR><TD CLASS="quote">check your connection at the vss, i had the same thing happen and ended cleaning the connector because it had too much resistance and only worked when i drove through water
so check that connector first!</TD></TR></TABLE>
ok so the plug is definatly dirty i think theres a bunch of green stuff on it my question now is how the hell did you get in there to clean it? depin it and hit it with a wire brush? im gona try that.
4dr-Si
Sep 14, 2006 05:05 PM
EJ1_519
Feb 23, 2004 02:54 PM
