my spedo's gone crazy
ok so just today my spedo started acting all crazy sometimes when im driving it doesnt even move just stays at zero then sometimes it jumps up and down or sometimes itll shoot up to 60 when im goin no more then 30 and sometimes when im at a dead stop itll jump up a little. no cel. any ideas? vss or spedo problem?
Re: my spedo's gone crazy (e jay one)
was it cold out?
Re: my spedo's gone crazy (mk2machine)
not really maybe 65?
it was pushed in to far mabie thats wha tmine did when i was at a stop light it would jump to like 120 lol try pullin it out and push it back in
Re: (19992civichatch)
Classic VSS problem. Go get a new one at the junk yard.
check your connection at the vss, i had the same thing happen and ended cleaning the connector because it had too much resistance and only worked when i drove through water https://honda-tech.com/forums/images/smilies/emsad.gif
so check that connector first! |
Re: (96civb18c1)
ok well i changed the vss and now it doesnt work at all. ill check the connectors right now.
Re: (e jay one)
yeah whenever its cold out with my car, something causes the speedo to act up. If i punch the dash hard enough than it works and it jumps up to 180 then it comes back down to 30 (speed in which im travelling)
Re: (mk2machine)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96civb18c1 »</TD></TR><TR><TD CLASS="quote">check your connection at the vss, i had the same thing happen and ended cleaning the connector because it had too much resistance and only worked when i drove through water
so check that connector first!</TD></TR></TABLE> ok so the plug is definatly dirty i think theres a bunch of green stuff on it my question now is how the hell did you get in there to clean it? depin it and hit it with a wire brush? im gona try that. |
Re: (e jay one)
probably got a bad replacement vss. but still check for any obvious breaks in the wires as well as moisture around them.
