i made my own ground kit
went to home depot and got 5ft of 4g wire and now i have about 3.5ft left.
i only replaced the valve cover to chassis, tranny to chassis, and battery to chassis.
what else needs to be grounded using 4g?
Search is your friend:
https://honda-tech.com/zerothread?id=116452
https://honda-tech.com/zerothread?id=533894
https://honda-tech.com/zerothread?id=1805876
https://honda-tech.com/zerothread?id=1433376
https://honda-tech.com/zerothread?id=477625
https://honda-tech.com/zerothread?id=943867
https://honda-tech.com/zerothread?id=901883
https://honda-tech.com/zerothread?id=634211
https://honda-tech.com/zerothread?id=490068
https://honda-tech.com/zerothread?id=503119
https://honda-tech.com/zerothread?id=213972
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by type B16 »</TD></TR><TR><TD CLASS="quote"> i made my own ground kit
Then you ask for help, Which is it?
i don't get it.. isn't all that stuff grounded from factory? what do people achieve by doing this. if your car dims in/out. you need new/better battery or repair your alternator. or if you have startup problems, replace your igintion components more often.. and clean termninals.. just my .2 cents for making a spiderweb inside engine bay..
and most important:
don't know how everyone does it, but certain electronics require direct ground and no looping for best performance.. - theres a reason some grounds aren't looped from factory
and most important:
