Spoon B18c
I Havea JDM B18C with a spoon head ..... from what i can tell the bottom end is stock ... if boosted how much can it take and what do i need to do to boost big (20lbs)
help please
help please
yeeah. boost forum.
but you will have to sleeve the block and have strong connecting rod and low compression pistons and maybe alot of other stuff..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondaspoon »</TD></TR><TR><TD CLASS="quote">I Havea JDM B18C with a spoon head ..... from what i can tell the bottom end is stock ... if boosted how much can it take and what do i need to do to boost big (20lbs)
help please </TD></TR></TABLE>
you will need to make a hole on your wallet
stock it can take 300whp for long enough for you to enjoy it if its tuned good.
I'm guessing 20lbs will put you around 400+ whp, so your going to need rods, pistons, and sleeves. You also need a whole mess of other stuff to support the turbo setup and the big numbers your going to be putting down, its not just the motor.
