Spoon b18c
Old Jan 29, 2007 | 07:07 PM
Hondaspoon's Avatar
Default Spoon b18c
i have a b18c with a spoon head i recently replaced main and rod bearings and all the stuff that goes along with it ... what would it tke to be able to boost upwards of 20lbs???
Old Jan 29, 2007 | 08:03 PM
aaronISthrowed's Avatar
Default Re: Spoon b18c (Hondaspoon)
You have alot of learning to do my friend.
Old Jan 29, 2007 | 09:13 PM
Schister66's Avatar
Man U FTW
the first thing you should learn is to ask questions w/ a real question in them....
20psi is a completely different thing from turbo to turbo....make your goals based on HP not PSI
Old Jan 29, 2007 | 09:22 PM
s2kdre's Avatar
Default Re: (Schister66)
boost is just a number, how much power do u really want?
Old Jan 30, 2007 | 06:14 AM
underpressure02's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondaspoon &raquo;</TD></TR><TR><TD CLASS="quote">i have a b18c with a spoon head i recently replaced main and rod bearings and all the stuff that goes along with it ... what would it tke to be able to boost upwards of 20lbs???</TD></TR></TABLE>
It depends do you have motec exhaust?
Old Jan 30, 2007 | 06:38 AM
93supercoupe's Avatar
Default Re: Spoon b18c (underpressure02)
whats a spoon head?
Old Jan 30, 2007 | 06:59 AM
JoePSI's Avatar
Default Re: Spoon b18c (93supercoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93supercoupe &raquo;</TD></TR><TR><TD CLASS="quote">whats a spoon head?</TD></TR></TABLE>
I got a spoon on my head but dont call me a spoonhead.
Seriously though, hes probably refering to a gsr head built by spoon, they build full engines, so he has the head from one.
My bet is that he was misinformed or is bullshittin out his ***.
Old Jan 30, 2007 | 07:05 AM
Default Re: Spoon b18c (BrokeBoosted)
^ hahah
Old Jan 30, 2007 | 09:34 AM
Soccerking3000's Avatar
Default Re: Spoon b18c (aaronISthrowed)
just for reference spoon usually just installs new pistons and keeps the stock rods so in terms of making a ton of power on a spoon block, it just wont happen, the tuning will be more finicky because of the higher static compression and as i said before it essentially has stock internals...
Old Jan 30, 2007 | 09:37 AM
JoePSI's Avatar
Default Re: Spoon b18c (Soccerking3000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 &raquo;</TD></TR><TR><TD CLASS="quote">just for reference spoon usually just installs new pistons and keeps the stock rods so in terms of making a ton of power on a spoon block, it just wont happen, the tuning will be more finicky because of the higher static compression and as i said before it essentially has stock internals...</TD></TR></TABLE>
good info, and the spoon pistons are cast arnt they?
Old Jan 30, 2007 | 10:41 AM
G
sh!t happens.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aaronISthrowed &raquo;</TD></TR><TR><TD CLASS="quote">You have alot of learning to do my friend.</TD></TR></TABLE>
why did you use Spoon?
Old Jan 30, 2007 | 11:10 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrokeBoosted &raquo;</TD></TR><TR><TD CLASS="quote">
good info, and the spoon pistons are cast arnt they?</TD></TR></TABLE>
yes i am 99% sure they are, someone correct me if i am wrong, all a spoon engine is a balanced and blueprinted type-r block with slightly higher compression...
Old Jan 30, 2007 | 11:52 AM
rudebwoy's Avatar
Default Re: Spoon b18c (G"UNIT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G"UNIT &raquo;</TD></TR><TR><TD CLASS="quote">
why did you use Spoon?</TD></TR></TABLE>
because 99.9 % ricers thinks the only ways is spoon, mugen, jun, greddy.
Old Jan 30, 2007 | 12:11 PM
doood's Avatar
been there done that
spoon pistons are nothing more than balanced sets of itr pistons
Old Jan 30, 2007 | 12:34 PM
Rosetta Stoned's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by underpressure02 &raquo;</TD></TR><TR><TD CLASS="quote">
It depends do you have motec exhaust?</TD></TR></TABLE>
a couple of sr20s will fetch a premium the week before race wars.
Old Jan 30, 2007 | 12:43 PM
RedEj8's Avatar
Default Re: Spoon b18c (Rosetta Stoned)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rosetta Stoned &raquo;</TD></TR><TR><TD CLASS="quote">
Not as much as 3 t66 turbos with nos.Even tho theres a higher chance of blowing the welds on the intake manifold with them.
Old Jan 30, 2007 | 01:26 PM
the_unknown's Avatar
GDD Lonely Krew
lets not forget the tuna sandwich either guys.
i think i know what happened here:
OP saw and ad for used car
car was a rice rocket
OP had seen F&F 1,2, and 3
seller tells OP car has spoon head
motor is in fact blown
am i right?
and yes spoon motors are balanced factory motors. they are used in races that do not allow internal mods like forged rods and pistons. therefore you got owned
Old Jan 30, 2007 | 02:25 PM
psikotc's Avatar
"a couple of sr20s will fetch a premium the week before race wars."
WOW! LAUGHING MY *** OFF!
Old Jan 30, 2007 | 02:30 PM
TIGboy's Avatar
Default Re: Spoon b18c (RedEj8)
I dont get what it is with people and their insanley high pressure numbers??!?!
SpoonEF6
Feb 12, 2007 10:20 PM
Hondaspoon
Jan 29, 2007 11:07 PM
Hondaspoon
Jan 29, 2007 07:05 PM
Leopold Scotch
Aug 12, 2005 07:10 PM
PrecisionH23a
Sep 30, 2004 09:15 PM
