swap or boost help?
Old Jan 29, 2007 | 01:06 PM
95dsol's Avatar
Default swap or boost help?
hey ive got a 95 del sol sohc d15b7 and im thinking bout swaping it ... or boosting the d15 i dont know which one i should do imlooking for a good daily driver nothing overly fast bt something that cann get up and go if i need to such as a high 14 sec car what do u all think ? thanks
Old Jan 29, 2007 | 01:19 PM
lost_childxgunn's Avatar
Default Re: swap or boost help? (95dsol)
SSSWWWAAPP IT !!!!! .. put a b16 or a gsr in .. dont waste ur timr boosting a single slammer unless ur goin to fully build an boost it .. but for a daily driver tht has the power whn needed i recommend a b16 or gsr ,.. expletive evn a b20 non v would rip in the del sol .. so for money wise a b20 it pretty cheap .. like 500 for the long block .. thn u need a tranny (ls for like 300) an mounts 250 .. so yah tht would b the cheapist ab most reliable b20
Old Jan 29, 2007 | 01:31 PM
95ProjectEJ1's Avatar
How much including installation are you willing to spend? Depending on your price range, some options may be better than others.
Old Jan 29, 2007 | 01:37 PM
big-cat's Avatar
even though i am a boost kind of guy, i would say swap as well, i think a b18b is in order.
Old Jan 29, 2007 | 01:51 PM
Default Re: (big-cat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by big-cat &raquo;</TD></TR><TR><TD CLASS="quote">even though i am a boost kind of guy, i would say swap as well, i think a b18b is in order.</TD></TR></TABLE>
Best of both worlds big-cat, swap the LS and boost it . If you shopped around you could pick up a long block for pretty cheap and find a B16 or GSR tranny and then piece a turbo setup
Old Jan 29, 2007 | 03:12 PM
Syndacate's Avatar
Boost it on stock internals with a resonator and good exhaust and you'll run 14's and it'll be a great daily driver.
It'll cost you circum 2k. Well spent IMO, with a 2k budget on a turbo build you should have enough power to cream on I/H/E GSR's and B16's .
Old Jan 29, 2007 | 03:15 PM
BLUIZE256's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95dsol &raquo;</TD></TR><TR><TD CLASS="quote">hey ive got a 95 del sol sohc d15b7 and im thinking bout swaping it ... or boosting the d15 i dont know which one i should do imlooking for a good daily driver nothing overly fast bt something that cann get up and go if i need to such as a high 14 sec car what do u all think ? thanks </TD></TR></TABLE>
that shouldnt have even been a question. .SWAP IT. . GSR or TYPE-R if you could
Old Jan 29, 2007 | 03:33 PM
coneheadsracing's Avatar
Default Re: swap or boost help? (BLUIZE256)
I say boost it. I have to boosted sohc honda's, wouldn't have it any other way.
With that being said, if you are building your own kit, which most do, i wouldn't do the DD for your first kit, unless you are prepared to do some work. I first did my hatch, it was good, i just learned a ton of things on what happens when you make your own kit. Now i just put one on my DD four door, and took my time and knowledge from my last kit, and built this one. Thus far (knock on wood) all is good. Nothing is loosening up, gaskets aren't blowing out, so on so forth.
Now, swapping in an engine, weekend project at most, plug and play, and usually close hood and enjoy. Bang for the buck if done yourself and done right, can't beat a turbo.
Old Jan 29, 2007 | 06:55 PM
95dsol's Avatar
what do u think bout a t3 kit for my car how hard do u think it would be to install
Old Jan 29, 2007 | 06:57 PM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
Default Re: (95dsol)
boost
shady3260
Jul 24, 2010 06:00 AM
93hatch_minime
13
Apr 21, 2009 12:08 AM
dark_samurai73
Sep 3, 2008 04:32 PM
Popaloops
Oct 27, 2005 01:57 PM
jbell
Jul 31, 2004 04:38 PM
