Turbo ITR blowing white smoke only at startup ? help ....
Old Jan 28, 2007 | 11:46 PM
Cyber ITR's Avatar
Default Turbo ITR blowing white smoke only at startup ? help ....
heya guys
i was told by a friend of mine that my car blows white smoke each time i start up the engine, i didnt even know that before he actually told me, so i really dont know how long this been going on
its basically blows white smoke for like 2-3sec max and then stops
i've sort of done my research on H-T old posts and the white smoke doesnt have that sweet-burning-coolant smell at all and im not losing water/coolant
i changed my oil about 3days ago and the old oil looks normal black, there was no sign of coolant present and there is no milky / mayonaise on the bottom of my oil cap and my coolant looks perfectly clear green still
i even trashed the living hell out of the car for about 10mins boosting and the water level on my resevoir bottle remain the same, didnt overfill or anything so that comes to the conclusion that my headgasket still in good condition
the engine basically fully rebuilt with new rings, gaskets and seals not long ago
about 3000miles max
please help
Old Jan 29, 2007 | 12:53 AM
Stripped Honda's Avatar
99-0104
Default Re: Turbo ITR blowing white smoke only at startup ? help .... (Cyber ITR)
it is caused by bad valve seals or worn valve guides not too bad of a fix if it just the seals you can do it without removing the head
Old Jan 29, 2007 | 03:08 PM
Cyber ITR's Avatar
Default Re: Turbo ITR blowing white smoke only at startup ? help .... (Stripped Honda)
strange, cuz both of them has been changed with new ones on my rebuilt bout 3000miles ago
Old Jan 29, 2007 | 03:23 PM
Haleiwa-Brando's Avatar
This effect is also caused by water vapor in the fuel lines and/or gas tank.
I'm going to take a stab here that you don't have a catalytic converter...?
Old Jan 29, 2007 | 03:25 PM
GetawayInMoscow's Avatar
Default Re: Turbo ITR blowing white smoke only at startup ? help .... (Haleiwa-Brando)
OMG is it cold where you live?
I don't think there is anything to worry about. If there was a problem it would be more obvious. If it was valve related and you were burning oil, the smoke would be BLUE.
Old Jan 29, 2007 | 07:57 PM
Cyber ITR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Haleiwa-Brando &raquo;</TD></TR><TR><TD CLASS="quote">This effect is also caused by water vapor in the fuel lines and/or gas tank.
I'm going to take a stab here that you don't have a catalytic converter...?</TD></TR></TABLE>
funny that i actually washed the entire engine bay when when i changed the oil about 3 days ago and i used some degreaser as well
its summer at the moment in where i live, this is really annoying
Old Jan 29, 2007 | 08:02 PM
Cyber ITR's Avatar
and yeah i dont have a catalytic converter, just straight through exhaust with the rear muffler
Old Jan 29, 2007 | 08:42 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cyber ITR &raquo;</TD></TR><TR><TD CLASS="quote">and yeah i dont have a catalytic converter, just straight through exhaust with the rear muffler </TD></TR></TABLE>
With what you said, I say that your fine.
Old Jan 29, 2007 | 09:29 PM
Cyber ITR's Avatar
im gonna get someone to do leakdown test soon, just to make sure
when you do leakdown test, does the valve cover has to be taken off ??
Old Jan 29, 2007 | 09:40 PM
You need to keep it on.
&lt;-- had a 500whp Turbo ITR by the way
Old Jan 29, 2007 | 09:58 PM
Cyber ITR's Avatar
aightttt
gotta thread with ur setup man ??
Mikeedubb
Oct 14, 2011 03:57 AM
Joeski99Si
Aug 2, 2009 11:25 AM
powwie
Apr 20, 2006 08:58 PM
Ziggymidget5
May 22, 2005 03:47 PM
Layziebtnh055
10
Apr 16, 2004 02:22 PM
