next mod?
Old Jan 28, 2007 | 03:31 PM
Jamied's Avatar
Default next mod?
i have a 2000 SI..and i have intake, header, exhaust, short shifter. I just want to do an all motor setup. Not looking towards boost. what should i go for my next performance mod? i was thinking Intake manifold and a bored TB..any suggestions?
Old Jan 28, 2007 | 03:46 PM
turbociviccoupe's Avatar
Default Re: next mod? (Jamied)
my two cents...do some real work like pistons then some head work.
93eg2james's Avatar
have it tuned yet?
Old Jan 28, 2007 | 03:47 PM
Jamied's Avatar
well im considering going LS/Vtec
no i dont have it tuned..didnt think itd be worth it with the current mods
Syndacate's Avatar
Default Re: next mod? (93eg2james)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93eg2james &raquo;</TD></TR><TR><TD CLASS="quote">have it tuned yet?</TD></TR></TABLE>
He didn't do anything to it yet...
I/H/E don't require a tune.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbociviccoupe &raquo;</TD></TR><TR><TD CLASS="quote">my two cents...do some real work like pistons then some head work.</TD></TR></TABLE>
I have to agree.
Old Jan 28, 2007 | 03:50 PM
93eg2james's Avatar
Default Re: next mod? (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">
but could you benifit from it? YES! my tuner Joe Riley pulled 178 whp out a b16 with:
-Intake
-Header
-Exhaust
-Water/Methanol Injection
-300 CFM Intake Mani
-Skunk 2 stage 1 cams
Old Jan 28, 2007 | 03:51 PM
Syndacate's Avatar
-Intake
-Header
-Exhaust
-Skunk 2 stage 1 cams</TD></TR></TABLE>
Good for your tuner.
Though I said I/H/E
Not METH INJECTION, intake mani, and skunk 2 cams.
When you start adding **** like that you need a tune, you don't need one after I/H/E and it's pretty redundant to do so.
Old Jan 28, 2007 | 03:52 PM
Jamied's Avatar
yes but thats with cams and other mods..
what possible gains could i get froma tune with I/H/E..
when i get cams/gears. im gonna do springs and retainers also. but what about valves?
after that id get it tuned
Old Jan 28, 2007 | 03:54 PM
93eg2james's Avatar
Default Re: (Jamied)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jamied &raquo;</TD></TR><TR><TD CLASS="quote">well im considering going LS/Vtec
no i dont have it tuned..didnt think itd be worth it with the current mods</TD></TR></TABLE>
why, you have a b16
Old Jan 28, 2007 | 03:55 PM
Jamied's Avatar
yes but wouldnt i get more power if i were to swap out the b16 block and put a LS block in?
Old Jan 28, 2007 | 03:57 PM
all motor needs all the help you can get. you can go for high compression valves. and aftermarket valves are stronger also.
Old Jan 28, 2007 | 03:59 PM
Jamied's Avatar
what kind of valves would go good with, lets say the skunk2 stage 1 cams?
Old Jan 28, 2007 | 04:13 PM
any brand you wish although they are not necessary
Old Jan 28, 2007 | 05:08 PM
Jamied's Avatar
i know i dont have to take out the motor to do cams/springs/retainers, but what about valves?
Old Jan 28, 2007 | 05:11 PM
koa's Avatar
koa
id get some cams and other head goodies and work your way down. Youll be supprised how much cams open a motor.
Old Jan 28, 2007 | 05:17 PM
big-cat's Avatar
i think u have it back *** wards though as far as the IM an TB go. if u get a bigger TB or bore yours, your going to want to bore the IM as well
Old Jan 28, 2007 | 07:28 PM
Jamied's Avatar
where can i buy CTR Cams?
and do i need any special springs/retainers to fit the CTR cams?
Old Jan 28, 2007 | 07:45 PM
bmoua's Avatar
whats your suspension setup??rims/tires???
Old Jan 28, 2007 | 07:55 PM
CRAZYWILL2007's Avatar
dude work on the suspension if u really want to add some initial, and cornering speed to the car but with a all motor build u need to do the pistons, and def some head work and i know people have already said that but thats my personal opinion. either way what is really the question is what is the ultimate goal of ur ride if u just want good power and all motor then do more engine work (internal stuff) if u want to do some auto crossing do the suspension because with I/H/E and a suspension u can still race in the slightly modded bracket but after u mess with the internals u step up the the big boys and wont have as much fun unless ur on the same page as far as money with them. cheers
Old Jan 28, 2007 | 08:04 PM
Everyones Hero's Avatar
Default Re: (CRAZYWILL2007)
Why would he do pistons at the beginning of an all motor build?
I'd do the headwork first. Cams, valves, valve springs, & retainers. Then have it tuned.
Old Jan 28, 2007 | 08:34 PM
Drew17th's Avatar
how much money do you hae to spend??? as an all motor kinda guy myself i would say do head work...... and if you get ahold of cleanrice on here he can set u up with pretty amazing cams springs and retainers for a pretty great deal through rocket motorsports.... otherwise i would probably say go with some supertech products...
like always tho... ur build so have fun with it
Old Jan 29, 2007 | 03:01 AM
Jamied's Avatar
im kinda going to piece things up, until i get it all and do the work at one time. I already have the car lowered H&R Race springs, tokico illumina struts, DC Sports rear lower tie bar, rear upper strut bar.
ieatrice
30
Dec 6, 2011 07:43 PM
nicko360
Northwest (Sales)
17
Jan 26, 2007 09:29 PM
Shaka01
10
Jan 29, 2006 02:23 PM
jweller
Mar 26, 2004 08:44 PM
Rightside
12
Jul 23, 2003 04:50 PM
