weird eg voltage problem?
Old Jan 28, 2007 | 01:55 PM
judunty84's Avatar
Default weird eg voltage problem?
i have a stock 95 coupe with the exception of a SAFC II (i had it in my old car so i just put it in since i had it). i have only had the car for a few weeks and 3 times in the past week something kinda weird is happening. 3 times i have noticed that the voltage has dropped while driving from the normal 14.4v to around the 12.4-13.0v range. my first instinct was the alternator was going bad. but if i shut the car off and start it immediately again it runs at 14.4v. it just has occured just driving around town and just kinda all the sudden drops voltage. if i rev the car really hard it will jump up about a half volt. i checked the belt to the alternator and it is good and like i said when i restart the car it runs at the correct voltage at idle and at speed. any ideas? im stumped
Old Jan 28, 2007 | 03:00 PM
judunty84's Avatar
Default Re: weird eg voltage problem? (judunty84)
bumpity
Old Jan 28, 2007 | 06:25 PM
judunty84's Avatar
one more bump
Old Jan 28, 2007 | 07:04 PM
JSPECSIR's Avatar
the electronic load detector makes it do that. mine does it, it agravates the **** out of me. if you chip you ecu you can turn it off.
Old Jan 28, 2007 | 07:37 PM
judunty84's Avatar
Default Re: weird eg voltage problem? (JSPECSIR)
what is the purpose of the electronic load detector and why would it make the vehicle run at a lower voltage? so basically is this anything i should worry about?
Old Jan 29, 2007 | 03:23 AM
JSPECSIR's Avatar
i dont know why it does it, but if you leave you blower fan on 2 or higher it will stay up at 14v. that way it detects a load and keeps the voltage up.
sanimalp
28
Jul 28, 2008 02:35 PM
khiz
Mar 25, 2008 10:18 AM
aus_newbie
Jun 30, 2007 04:00 AM
nitrousrush
Nov 2, 2005 03:15 PM
99lude
Jan 13, 2004 06:34 PM
