BAD vibration after swap
Old May 16, 2002 | 06:33 PM
E-AT_me's Avatar
Default BAD vibration after swap
when i am accelerating, i get a bad vibration. i just did a swap in my CRX Si, 90, about a month ago, B16a. i am using Raxles axles and installed a new clutch. no check engine lights, no signs of a mis-fire. i dunno if it's coming from the tranny or the axles. anyone else experience this? it's like a shaking vibration that comes and goes. it doesn't really do it all the time.
Old May 16, 2002 | 06:49 PM
Trinity's Avatar
Default Re: BAD vibration after swap (Rexman)
motor mount maybe?
Old May 16, 2002 | 06:51 PM
Jared's Avatar
bad axle, bad tie rod end, bent wheel, broken motor mount? is it speed related or engine speed related. what can you do to reproduce it?
Old May 16, 2002 | 07:12 PM
spdster's Avatar
New User
Default Re: BAD vibration after swap (Jared)
I had a similar problem with my swap...it turned out to be exhaust related and would occur randomly...just make sure you have enough clearance for the exhaust to move around a bit...everything from the header on down.
Old May 16, 2002 | 07:33 PM
Giuseppe's Avatar
Default Re: BAD vibration after swap (spdster)
at idle, cruising, highway,?? oops nevermind..its when accelerating..
what mounts are u using.???
[Modified by Giuseppe, 11:34 PM 5/16/2002]
Old May 16, 2002 | 08:16 PM
Phatwhippin_CRX's Avatar
Default Re: BAD vibration after swap (Giuseppe)
What kind of mounts are you using? I know all 3 kits use rather stiff mounts, which give a crazy vibration for a while till they break in.... and even after that. 99% chance that it's the mounts, dont worry about it.... it's completely normal.
Old May 16, 2002 | 09:51 PM
91CivicSi's Avatar
I had the same problem. I'm using 90 Integra axles and it shook very badly when accelerating because I hadn't taken the spacers out of the hubs. I'm not sure about the Raxles but since I popped that spacer out it's been good to go.
Old May 17, 2002 | 08:03 AM
E-AT_me's Avatar
Default Re: BAD vibration after swap (91CivicSi)
hmmm. i'm thinking exhaust. mine is tensioned so it can't reall move. mounts are the new HASPORTS. i don't think it did it when i had the open header, though, so imma try the exhaust..
Old May 17, 2002 | 08:38 AM
EL Vap133's Avatar
I know this sounds weird, but check your lug nuts on your front tires....
Old May 17, 2002 | 09:30 AM
HumanResource's Avatar
I know what you mean man. I'm using the Place Kit and Vibration with the clutch out is not that bad, but in gear, it almost seems that something is not balanced, then goes away at higher RPM. I'm going to be checking out my axles. From what I've heard around is that it could be my axles, or lugnuts. My exhaust make a short noise and vibration, but I can tell the difference and I don't think it's that.
Old May 17, 2002 | 10:00 AM
tunedcivic's Avatar
Default Re: BAD vibration after swap (Chris90STD)
place kit in my car shakes my dash and all even my seats sometimes at the lights...kinda enbarasing. shifting is really firm too, but when i am driving it doesnt vibrate, only at idle.
Old May 17, 2002 | 10:01 AM
Eggman's Avatar
happens to me too. comes and goes. gets worst with travel speed. goes away after some turns (left or right). i know its axle related. which axles is everyone running?
[Modified by Eggman, 11:03 AM 5/17/2002]
Old May 17, 2002 | 12:35 PM
Default Re: BAD vibration after swap (Eggman)
I've got 92 GSR ones in there now.... switching them out for raxles next week......
Old May 17, 2002 | 02:08 PM
i got these from PLACE
I'm running the Y1 Int shaft with the Y1 LSD trans.
He asked if I was running the "TRUE SiR" engine and trans, I said yeah, So that's what he sent me.
Old May 17, 2002 | 06:28 PM
E-AT_me's Avatar
thanks. i know it's not the lugs, i tighten them every week. with a torque wrench. (avid auto-xer)
as for my Axles, they are the Raxles Si-R axles, with an Si-R intermediate shaft.
i'm going to try the exhaust thing. considering it hangs really wierd.
JDMB20TDA
13
Mar 13, 2010 03:59 PM
BukakkEK9
Oct 28, 2006 11:40 PM
IVGattaBeDreaming
11
Sep 5, 2006 11:42 AM
Mr. Vapor
Jun 29, 2006 04:43 AM
Azn Kenny
Nov 19, 2005 05:42 PM
