Is there anyway to trouble shoot a MAP sensor (89 prelude SI)
Old Jan 26, 2007 | 12:29 PM
stocker2shocker91's Avatar
I requested a short story for a title.
Default Is there anyway to trouble shoot a MAP sensor (89 prelude SI)
Hey guys i have been messing around with this car for a long time now and it seems like i have checked everything. I have gotten rid of all the codes so far except for the map code.
I know there is a box on the firewall that has all the hoses and is the vacuum control. But is there something else i might need to check
I want to trouble shoot it before i just go buying new stuff. please help me out, thanks
Old Jan 26, 2007 | 12:30 PM
mgags7's Avatar
Make sure the map is plugged in, the wires are sound, and the vac hoses are sound, beyond that you can't do much troubleshooting.
If none of those show a problem, replacing it isn't very expensive.
Old Jan 27, 2007 | 06:18 AM
H22 3rd Gen's Avatar
Default Re: Is there anyway to trouble shoot a MAP sensor (stocker2shocker91)
just make sure all your hoses and wires are in good condition and there are no vacume leaks if this is correct then replacingthe map sensor is not to expensive bro max $60 at your local parts store, post anymore questions if you have em i have have same car...
-mikey
Old Jan 30, 2007 | 07:33 AM
Default Re: Is there anyway to trouble shoot a MAP sensor (H22 3rd Gen)
ok i checked all that as much as i could (tons of snow today)
it will idle fine, then right when you give it gas it will stumble and backfire a little bit, then when it gets about about 2,000rpm, its fine. is that a map sensor side effect?
si_motor_spt
Sep 9, 2007 12:31 PM
david22ky
19
Aug 21, 2007 08:11 PM
whitestreak
Mar 3, 2007 05:56 AM
Tex Blackwell
Apr 13, 2005 04:03 PM
sakums20
Apr 29, 2004 02:40 PM
