Rookie GSR turbo build!!!!!
Old Jan 25, 2007 | 07:34 PM
bustdgst's Avatar
Default Rookie GSR turbo build!!!!!
ok so im kinda new to the whole turbo honda thing. In the process of building my gsr block and I had a few questions...would it be safe to run 10.5 compression forged pistons with scat rods on a turbo set up that consists of a gsr block with b16 head?? last question is that the hell is a resistor box??? I purchased a set of 550 dsm injectors and from research i found out that I need to use a resistor box. Again I have a b16 head...thanks!!!!!!
Old Jan 25, 2007 | 09:41 PM
blinx9900's Avatar
Default Re: Rookie GSR turbo build!!!!! (bustdgst)
youll be fine with 10.5, resistor box will makes those injecors work properly, search in the future before you post. the archives have a lot of good info.
Old Jan 25, 2007 | 10:24 PM
s2kdre's Avatar
Default Re: Rookie GSR turbo build!!!!! (blinx9900)
10.5 is perfect
Old Jan 25, 2007 | 10:42 PM
iBrandon's Avatar
Default Re: Rookie GSR turbo build!!!!! (s2kdre)
Like its been said again and again around here...Get it tuned properly and you should have no trouble!!
Old Jan 26, 2007 | 05:23 AM
Teg6's Avatar
Default Re: Rookie GSR turbo build!!!!! (iBrandon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iBrandon &raquo;</TD></TR><TR><TD CLASS="quote">Like its been said again and again around here...Get it tuned properly and you should have no trouble!! </TD></TR></TABLE>
Take it from a Rookie himself who did a turbo job. It is always best to have it tuned pro even if you don't have the money. $400 could save your $3500 motor.
Old Jan 26, 2007 | 05:39 AM
Schister66's Avatar
Man U FTW
DSM 550s?? What car are those from....i thought they only came in a 440cc...
Old Jan 26, 2007 | 05:50 AM
bustdgst's Avatar
aftermarket dsm injectors...not stock
Old Jan 26, 2007 | 05:51 AM
bustdgst's Avatar
will any resistor box work?? I saw a few for sale on this forum...any diagrams or info on how to hook on up??
Old Jan 26, 2007 | 07:49 AM
markaria's Avatar
Although it can be done with a spot on tune, if I were you I would use a bit lower compression... especially for your 1st build. I would suggest perhaps 9:1 or 9.8:1 etc. since running 10.5:1 leaves a VERY small window for things such as a boost spike or bad tank of gas...
...but of course all of ht now knows that since its 2007, its perfectly fine to run 14:1 compression and 30 psi of boost using a gt42r with 1.5L of displacement and 87 octane gas that has sat for a year... ha ha
Good luck to you and unless you have unlimited funds better to be safe than sorry... Dont forget the old saying : Fast, Cheap, Reliable... you can have any 2 that you want.
Old Jan 26, 2007 | 12:00 PM
bustdgst's Avatar
good info...thanks!!!!
Old Jan 26, 2007 | 01:01 PM
Jason703Racing's Avatar
Default Re: (bustdgst)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bustdgst &raquo;</TD></TR><TR><TD CLASS="quote">aftermarket dsm injectors...not stock</TD></TR></TABLE>
he prob got dsm 510cc injectors. Dsm's in JDM Y0 land came stock with the yellow top 510's and a 16g turbo. The evo 3 motors had them along with certin galant motors.
Old Feb 13, 2007 | 05:50 PM
bustdgst's Avatar
another thing I heard is that I would need injector clips...would I be able to get away with using those injecors and a resistor box?
Old Feb 14, 2007 | 01:12 AM
vtecspeed1320's Avatar
Shooting Star
new evo 8's are 560's....
TomCurllyFry
Feb 12, 2013 06:24 PM
luvmihatch
Sep 22, 2008 07:59 AM
LsScivic
May 4, 2008 07:24 PM
integracivic94
Jan 10, 2005 09:32 AM
