**1990 Civic Std brake Help**
Old Jan 25, 2007 | 03:17 PM
Themouse's Avatar
Default **1990 Civic Std brake Help**
Ok i just picked up a 1990 civic STD 4 speed for the winter it needed new rear wheel cylinders and i replaced both side the pads are all good on all four ends.
The Question:
I have bled the brakes to many times to count and i only have alittle bit of pressure when the brake pedal is close to the floor or i pump it ounce or twice while driving to get a good amount of pressure what is going wrong thanx guys
Old Jan 25, 2007 | 03:25 PM
JJ's civic's Avatar
Default Re: **1990 Civic Std brake Help** (Themouse)
try a master cylinder. had the same prob
Old Jan 27, 2007 | 12:39 PM
Themouse's Avatar
Any more ideas
Old Jan 27, 2007 | 05:26 PM
Hondasmo's Avatar
check the adjustment on rear drum brakes might need to adjust them up if you say it takes 2 tries to get the pedal up
Old Jan 27, 2007 | 08:58 PM
Themouse's Avatar
Default Re: **1990 Civic Std brake Help** (Hondasmo)
ooh ok thanx guys i will try that all tomorrow
KillAhKev
Mar 10, 2012 12:11 AM
91integra91
13
Aug 20, 2011 09:00 AM
ej6.sean
13
Feb 3, 2010 08:17 AM
spoolinegsr
21
May 30, 2007 11:38 AM
HotRodTeg
Nov 24, 2003 11:13 PM
