need help to get correct oil line kit for a garrett t3/to4e turbo
Old Jan 25, 2007 | 08:52 AM
malubawla's Avatar
Default need help to get correct oil line kit for a garrett t3/to4e turbo
hey i have a Garrett 57 trim t3/t04e with a .63 a/r
where should i buy my oil line kit from, i know that shealthlines, fast-turbo sell them
can someone please send me a link for the proper kit for my turbo.....thanks alot
Old Jan 25, 2007 | 11:27 AM
Schister66's Avatar
Man U FTW
http://www.stealthmodeperformance.com
Old Jan 25, 2007 | 12:08 PM
malubawla's Avatar
Default Re: (Schister66)
doesnt have any lines for a t3/t4 turbo
Old Jan 25, 2007 | 12:10 PM
RedEj8's Avatar
Default Re: (malubawla)
yes it does...http://www.stealthmodeperformance.com/oil-kit.shtml
Old Jan 25, 2007 | 12:23 PM
malubawla's Avatar
Default Re: (RedEj8)
14B (Tdo4h) Turbo Oil Line
14B uses a M12x1.25 thread size for the oil inlet. The drain flange from center to center mounting bolts measures 38mm. This kit does not come with the mounting bolts to bolt the drain flange onto the turbo. There are many different sizes used on different variations of the 14B, leaving us to choose not to carry them.
T25 Turbo Oil Line
kit uses a 7/16 thread size for the oil inlet. The drain flange from center to center mounting bolts measures 44mm.
T3 Turbo Oil Line
kit uses a 1/8 thread size for the oil inlet. The drain flange from center to center mounting bolts measures 50.8 mm.
T3 Turbo Specia Turbo Oil Line
kit uses a 1/4 thread size for the oil inlet. The drain flange from center to center mounting bolts measures 50.8 mm. It also uses different mounting bolts for the drain flange. This has only been found on new turbos thus far.
GT Series Turbo Oil Line
kit uses a 7/16 thread size for the oil inlet. The drain flange from center to center mounting bolts measures 50.8 mm. This is for the GT35r, GT28 ect turbos.
so which one is it??
carbon fiber coupe's Avatar
stealth mode ftw!
ive ran on both my turbo builds never failed yet
Old Jan 25, 2007 | 04:05 PM
malubawla's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by malubawla &raquo;</TD></TR><TR><TD CLASS="quote">14B (Tdo4h) Turbo Oil Line
T25 Turbo Oil Line
T3 Turbo Oil Line
so which one is it??</TD></TR></TABLE>
so which one do i buy????
Speedra500
Sep 5, 2008 05:59 PM
levee000
Jul 11, 2008 10:27 AM
kaohli_yang
Nov 18, 2007 05:44 PM
AaronJ
Jun 26, 2006 05:05 AM
zccr-xsi
Mar 19, 2006 08:10 PM
