need to know the stock bore?
Old Jan 24, 2007 | 04:31 PM
ILOVEYOURHONDA's Avatar
Default need to know the stock bore?
i need to know the stock bore for a b18b is and what do you think are the best pistons and rods and if i should just use stock sleeves?
Old Jan 24, 2007 | 04:51 PM
unknown0001's Avatar
Default Re: need to know the stock bore? (ILOVEYOURHONDA)
81mm bore
http://en.wikipedia.org/wiki/Honda_B_engine
Old Jan 24, 2007 | 04:53 PM
Default Re: need to know the stock bore? (Mr.RHTuner)
thanks man
Old Jan 24, 2007 | 05:14 PM
viet_boi_racin's Avatar
stock bore is 81mm. And you can run just about any piston and rod you want with stock sleeves. Just gotta make sure its the right compression that you want. and for a LS motor. otherwise your compression will be off.
Old Jan 24, 2007 | 05:30 PM
Default Re: need to know the stock bore? (viet_boi_racin)
yeah i kinda want something high so i can go all motor but then again i kinda want like 9.5.1 so i can boost it....if you have high compression can you spay?
Old Jan 24, 2007 | 05:43 PM
doood's Avatar
been there done that
nitrous loves high compression. you just need a good tune.
Old Jan 24, 2007 | 05:52 PM
Default Re: need to know the stock bore? (doood)
do you have to tune if its a small shot like a 50 shot?
o0o_tylor_o0o
Dec 7, 2010 07:03 PM
ohsnapzafingcu
Feb 28, 2009 10:36 AM
digital sol
Jan 20, 2006 03:27 PM
tobe1424
12
Jan 17, 2006 12:17 PM
h22squeaker
Jun 12, 2003 12:04 PM
