Check Engine Light
I have a Check Engine Light that just came on yesterday after i picked my car up at a shop, they had just put a new oil pan and oil gasket on and to do this they had to drop the exhaust system down so what could have happend? Im going to jump the ECM and read the code, but i wanted to know what you guys think? thanks
22 - VTEC System Malfunction
Uh oh. Is your VTEC "kicking in?" Reset the ECU... pull the ECU fuse and let it sit for like 10 minutes, then put it back. See if the light comes back.
Edit: Probably won't change a damn thing, but, hey, always do the "reset the ECU trick" first before you start checking wires and lines.
[Modified by 4doorH22, 6:54 PM 5/16/2002]
yeah, my Vtec is not kicking in i noticed today on the way home. Ill give the ECU a reset tomorrow afternoon, ill let yall know what happens, thanks
