could bad HG cause hydrolock and piston smash through block ?
Old Jan 24, 2007 | 07:36 AM
97grnrs's Avatar
Default could bad HG cause hydrolock and piston smash through block ?
on my turbo zc its been havin a sputter at high rpm lately so i got pissed and floored it after replacing everything else and #4 cyl rod and piston got all smashed up and went everywhere so i took it apart and the HG didnt look too bad but im thinkin it had a slow leak and that was causing the miss in cyl4 and when i floored it it just went completely and flooded the cyl with antifreeze and hydrolocked it, is that poss or no?
Old Jan 24, 2007 | 07:57 AM
turbotime's Avatar
probably possible yet not very likely... pics?
Old Jan 24, 2007 | 08:30 AM
97grnrs's Avatar
Default Re: (turbotime)
[IMG]
Old Jan 24, 2007 | 11:06 AM
RudeLude's Avatar
Default Re: (97grnrs)
WOWSKIE!!!!
Old Jan 24, 2007 | 11:17 AM
ham's Avatar
ham
Default Re: could bad HG cause hydrolock and piston smash through block ? (97grnrs)
HOLY MOLY!!!
tune or HG maybe?
Old Jan 24, 2007 | 11:43 AM
97grnrs's Avatar
Default Re: could bad HG cause hydrolock and piston smash through block ? (ham)
can u believe it drove home like that. for about 3 blocks.. and it ran. did not knock at all. just sounded like a helicopter.. id like to figure out what caused it so i dont do it again.. im thinking HG was slowly leaking into that cyl for a week or so and when i hammered it it just blew fully. it was a stock internal zc . never did hg or anything to it. had about 70K on it . the si motor i just put in runs stronger than the zc did so i dunno whats goin on
RedEj8's Avatar
Ouch..Show a pic of the cylinder and head.
Old Jan 24, 2007 | 11:59 AM
m R g S r's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97grnrs &raquo;</TD></TR><TR><TD CLASS="quote">can u believe it drove home like that. for about 3 blocks.. and it ran. did not knock at all. j </TD></TR></TABLE>
lol hard to believe but i guess i could see it still running on 3 cylinders while **** is gettin mashed up inside that poor poor motor
Old Jan 24, 2007 | 12:09 PM
97grnrs's Avatar
Default Re: could bad HG cause hydrolock and piston smash through block ? (m R g S r)
ya cause it didnt knock it just must have crushed all at once. the head is barely scratched . maybe one valve it may need but other than that its ok. it all went out sides and bottom. smashed the girdle and oil pan and all
Old Jan 24, 2007 | 12:38 PM
93supercoupe's Avatar
yeah, i blew a rod threw an LS and drove it home for like 5 miles, and when i got there, i drianed the oil, ran it until it died w/ the rod sticking out the block, waited until it cooled, started it AGAIN, poured water in the TB and it went on like this until i pulled it out.
I couldnt kill this pile of ****, lol.
27
Jan 13, 2009 09:06 PM
THEDirtyDseriesWOOT
Feb 22, 2008 05:51 AM
welfarepc
Oct 12, 2007 12:31 PM
got wide
Sep 4, 2007 03:55 PM
1BadCvC
Mar 22, 2004 08:05 PM
