Castrol in plug hole #1
Old Jan 24, 2007 | 07:14 AM
Andrew Sutherland's Avatar
Default Castrol in plug hole #1
So last night a friend and I were cleaning my air filter and a few other misc maintenance things under the hood, and he was using some castrol-simple green like stuff (oil & grease remover) in liquid spray form to clean the oil and crap off my valve cover. He used too much, and some got into the top of cyl #1 (far right).
Didnt notice, we finished up and I started the car, only to be greeted with what sounded like a whole lot of ignition problems. Turned the car off right away, and found liquid in the hole. We managed to sop up almost all with paper towel etc and tried it again. Much better results.
As I drove home, I noticed as soon as I stepped on the gas more than like 10% throttle it would sputter and lag almost like it was not firing on that cyl. Got it home ok, and removed the plug wires to let it dry overnight.
Still having the same problem this morning, even though under inspection the spark plug hole looks dry.
What should I do? Should I replace the spark plug(s)? I'm afraid to take it out, because then if there's any leftover liquid it might fall underneath the plug?
Old Jan 24, 2007 | 07:22 AM
OG undercover's Avatar
Default Re: Castrol in plug hole #1 (Andrew Sutherland)
Use a vacuum
Old Jan 24, 2007 | 07:23 AM
walker111's Avatar
I dont see why the stuff wouldnt dry out and be fine... Did you clean more than just the valve cover? Did you spray the hole engine bay down with water? Moisture in dizzy???
Old Jan 24, 2007 | 07:24 AM
Default Re: Castrol in plug hole #1 (walker111)
We didn't spray the whole engine down, no...
Old Jan 24, 2007 | 07:32 AM
walker111's Avatar
Did you spray the dizzy?
Old Jan 24, 2007 | 07:38 AM
Nope
*edit - I dont THINK so. I didnt, but I will double check with him. If he did, what do I need to do?
Modified by Andrew Sutherland at 11:21 AM 1/24/2007
Old Jan 24, 2007 | 10:20 AM
nafreak's Avatar
maybe the cleaner did something to the plug boot? corroded the connector inside?
BTW: LEN called me MR. Crybaby! LOL! thats a gRRRRReat username!
Old Jan 24, 2007 | 10:47 AM
vtec2nv's Avatar
Default Re: Castrol in plug hole #1 (nafreak)
pull the wires and inspect them. look down the spark plug holes, and make sure there is no liquid sitting there. If you are worried that there is still some left in the motor....plug all the plugs out. Take the f.i. fuse, and ecu fuse out, and crank the motor over, stop. Then crank the motor over again. i saw at least 5-6 turns both times(you can do it more than 2 times if u have liquid coming out. If there is anything in there it should come out. This is just MY ADVICE. hope it helps....
Old Jan 24, 2007 | 01:17 PM
Looks like that's exactly what happened. Swapped the plug wires out for other ones, and it runs fine.
Unforunately, these were Crane Cams wires worth about $140 Is there any way to fix them?
Old Jan 24, 2007 | 02:25 PM
vtec2nv's Avatar
yea let them dry/clean them off you should be ok.
Old Jan 24, 2007 | 06:10 PM
h8ted ek's Avatar
Default Re: Castrol in plug hole #1 (vtec2nv)
The past two times i cleaned out my engine bay, My spark plugs always seemed to get wet. anyways. I had the same problem, it will sputter lag, Use more towel rage and keep soaking it up and dry it as much as possible. oh and by the way you may need to change spark plugs. goodluck
Old Jan 26, 2007 | 07:36 AM
Problem solved!!!!
After replacing the wires, AND then the plugs - she's back up to her regular step-on-it-and-get-2nd-gear-tirespin beast!
Old Jan 26, 2007 | 07:55 AM
Arsenal's Avatar
Default Re: (Andrew Sutherland)
You can also use WD40. Its what its intended for...
SeanaK
Jun 24, 2014 03:22 PM
el_toro_de_magnifico
Apr 15, 2008 11:13 PM
HCJDM1
19
Dec 12, 2007 09:41 AM
HTn00b
43
Nov 8, 2006 02:35 PM
Michler
Apr 17, 2006 06:59 PM
