stock B18B quater mile time...
Old Jan 24, 2007 | 05:23 AM
. r i c h 9 9 0's Avatar
Default stock B18B quater mile time...
hey whats up, sorry for the noob question, i've done a search but nothing came up.....
what time are you guyts running with stock B18B's over the quater mile??
im just trying to get some indication of what i can expect to get tomorrow, im having my first timed runs so i wanna know if what i get is good or not?? although the traction here in South Africa (well i've heard especially my local strip) is really bad...
my car is as follows..
99 ek ferio
B18B (came stock in the car in south Africa)
SHORT RAM INTAKE/4-1HEADER/51MM 3 BOX EXHAUST
195/50/15 yokohama A539 tyres...
what do you guys think ishould get with this setup??
/*ps i know this should prob. go in the hybrid forum but i figgured that most guys who do a swap do some work before dropping the engine, there must be a couple guys withINTERNALLY stock LS's... lemme know your times!!!
ps here's my car...
thanks in advance
rich
south Africa
Old Jan 24, 2007 | 06:24 AM
unknown0001's Avatar
Default Re: stock B18B quater mile time... (. r i c h 9 9 0)
-1995 b18b(fresh rebuild--new rings + bearings)
-2000 b16a2 transmission
-10lb Jun Flywheel
-Exedy Stage 1 clutch
-CTR N1 crank pully
-J's racing intake
-Pro-1 ITR 4-1 header
-2.5" piping with 2.5" high flow cat
ran the timeslip below
Reaction - .8729
60ft - 2.2721
330ft - 6.3409
ET @ 594ft - 9.0869
1/8 ET - 9.6991
1/8 MPH - 73.51
1/4 ET - 15.0020
1/4 MPH - 90.54
Old Jan 24, 2007 | 07:08 AM
Default Re: stock B18B quater mile time... (Mr.RHTuner)
awesome, yr coupe is clean as a whistle!!
good time too!!
i think with the traction here i might pull a 15.5 at best... its so bad i spin into 3rd with a stock B18b
im guessing that clutch and flywheel helped you quite bit
Old Jan 24, 2007 | 07:11 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by . r i c h 9 9 0 &raquo;</TD></TR><TR><TD CLASS="quote">awesome, yr coupe is clean as a whistle!!
good time too!!
im guessing that clutch and flywheel helped you quite bit </TD></TR></TABLE>
thanks man!
I just know that when I peiced together the setup, I could have got a b16 but I think the b18b is a better choice as it can be a beast of a NA engine or slap on a vtec head a few additional parts and you can have a great ls/vtec.
I think what helped was a combination of the flywheel, short gearing of the SIR transmission and the CTR n1 crank pulley
Old Jan 24, 2007 | 07:16 AM
yea i forgot bout the S4c (SIr) tranny...
what time do u expect i'd get witht the stock LS tranny?? mine's an S4c casing with the S80 (LS) gearing??
Old Jan 24, 2007 | 07:54 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by . r i c h 9 9 0 &raquo;</TD></TR><TR><TD CLASS="quote">yea i forgot bout the S4c (SIr) tranny...
what time do u expect i'd get witht the stock LS tranny?? mine's an S4c casing with the S80 (LS) gearing??</TD></TR></TABLE>
well, with your current clutch/flywheel/factory crank pulley, transmission gearing...and the weight of the 4dr your maybe looking at mid/high 15's?
hard to say tho man
Old Jan 24, 2007 | 08:08 AM
yea thats what i thought.. prob between 15.5 and 15.9.
anyway, thanks for the help mate. i'll post up what i got tmw here for future reference...
Old Jan 24, 2007 | 10:57 AM
integra racr04's Avatar
my boy ran a 16.3 in his 4door ferio with I/E/H, so with that same set up on a B18B, you should expect something around 15.7ish...maybe lower if you know how to drive...post up a slip with you find out...
Old Jan 24, 2007 | 03:39 PM
Import_spoon's Avatar
I got my stock B18B with B16A tranny and I/E 2.5 piping and i ran a 14.2 with my snow tires.
Old Jan 24, 2007 | 03:58 PM
Default Re: (Import_spoon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Import_spoon &raquo;</TD></TR><TR><TD CLASS="quote">I got my stock B18B with B16A tranny and I/E 2.5 piping and i ran a 14.2 with my snow tires.</TD></TR></TABLE>
What chassis? how much did it weigh? stripped or full? hard to believe.
Have a time slip?
Old Jan 24, 2007 | 04:20 PM
Abandoned Ship's Avatar
New medicines
bs on the 14.2 if the car isnt an EF
Old Jan 24, 2007 | 04:38 PM
Default Re: (i heart Vans)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by i heart Vans &raquo;</TD></TR><TR><TD CLASS="quote">bs on the 14.2 if the car isnt an EF </TD></TR></TABLE>
exactly.
My car is a big heavy, but lighter then a factory 94+ teg and with all the I/H/E, tranny, flywheel and crank pulley I was only able to pull out the lowest of a 15.0020
I could understand hitting a 14.7 max, but 14.2 is hard to believe without a timeslip
Old Jan 24, 2007 | 04:41 PM
t . b o z's Avatar
I ran a 15.1 @ 88mph with my old b18b.
Old Jan 24, 2007 | 05:58 PM
Default Re: (Mr.RHTuner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.RHTuner &raquo;</TD></TR><TR><TD CLASS="quote">
Have a time slip?</TD></TR></TABLE>
The interior was stripped at that time. Now its back to normal just because i wanted it clean inside. Its a B18B1 in a 94 Civic Hatch. This was a while ago. I don't have the time slip no more but i'm planning to go run again when i get the Ls-V in. lol
Old Jan 24, 2007 | 10:27 PM
Oleg's Avatar
what was your trap time??
. r i c h 9 9 0
Jan 24, 2007 07:27 AM
Kafelatte
Dec 22, 2006 05:58 AM
imskatencrzy
11
Dec 22, 2005 01:27 PM
93EH6
73
Mar 11, 2005 12:08 AM
The Rob
Jun 25, 2002 11:24 AM
