ls-vtec
Old Jan 23, 2007 | 05:04 PM
4dreg's Avatar
Default help on ls-vtec conversion
ya im doing a ls vtec conversion and i have some questions. lots of people are saying diffrent things about the conversion. one thing is that you have to use a gsr timing belt and waterpump, is that true? another is that you cant use b16 head bolts because it will strip the ls block. can you use the ls head bolts? i wanted to use my timing belt and water pump what should i do? if i use the ls water pump and timing belt it was said it would be to loss. do i need to use a gsr oil pump or can i use the ls oil pump? i just need some info on the ls vtec conversion.
p.s what are the torq specs on the gsr head bolts
Modified by 4dreg at 8:32 AM 1/24/2007
Modified by 4dreg at 2:23 PM 1/24/2007
Old Jan 24, 2007 | 01:25 PM
4dreg's Avatar
Default Re: help on ls-vtec conversion (4dreg)
Old Jan 24, 2007 | 02:18 PM
doood's Avatar
been there done that
read this: https://honda-tech.com/zerothread?id=1676914
Old Jan 25, 2007 | 09:23 AM
4dreg's Avatar
Default Re: help on ls-vtec conversion (doood)
thanks
Old Jan 25, 2007 | 01:52 PM
4dreg's Avatar
should i change the ls oil pump? someone told me it dosent matter
Old Jan 25, 2007 | 01:57 PM
B18CivicEH2's Avatar
change them while you're at it...change the water pump too..
Old Jan 25, 2007 | 03:18 PM
doood's Avatar
Default Re: help on ls-vtec conversion (B18CivicEg)
all 96+ b series oil pumps are the same. you might as well replace it if you have everything apart. use a vtec water pump too while you're at it.
804tuned
Engine Management and Tuning
Feb 17, 2009 01:28 PM
parfait2882
Apr 12, 2007 08:00 PM
SL0WEGG
May 5, 2005 02:51 PM
GEN2INTEG619
Mar 27, 2005 04:57 PM
