jun
Old Jan 23, 2007 | 08:51 AM
Jdm integra DB8's Avatar
Default jun
Can you guys tell me what should to do the head so i can get the best power out of some jun type 3
1.without touching the bottom end
2. run on pump gas and some times on racing gas
3. depenable
4. smooth idle
5. and not costing to much
6. Goal 200whp
Modified by Jdm integra DB8 at 10:08 AM 1/23/2007
Modified by Jdm integra DB8 at 10:09 AM 1/23/2007
Old Jan 23, 2007 | 09:15 AM
Rosetta Stoned's Avatar
Default Re: jun (Jdm integra DB8)
All those "requirements" and you didnt even tell us anything else about your motor.
Old Jan 23, 2007 | 09:27 AM
Default Re: jun (JDM_G2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_G2 &raquo;</TD></TR><TR><TD CLASS="quote">Stock bottom end and stock head with some tuning and youll be close to 200whp!!! </TD></TR></TABLE>
Do you know what kind of block/head he has?
Kinda hard to just spout off HP #'s with no specs eh?
Old Jan 23, 2007 | 09:57 AM
Default Re: jun (Rosetta Stoned)
I have a 0b2 jdm gsr it is stock right know but i want to put some jun 3 cams but i don't know what else should a do to the head . Like what valvetrain should a i use.
Old Jan 23, 2007 | 10:12 AM
1 2 NV's Avatar
i hate to say it but this is the type of **** belben was talking about. this would be better off locked and deleted.
if you want 200WHP you will have to spend money period. quit being cheap cause HP costs money.
Old Jan 23, 2007 | 10:19 AM
Default Re: jun (1 2 NV)
I am not being cheap the most i will spend is 2,000 on the head
Old Jan 23, 2007 | 10:21 AM
If you guys wanted to make a head package want would be in it. with some jun type 3 cams
Old Jan 23, 2007 | 10:24 AM
Why are you so dead set on JUN cams?
I suggest SEARCHING before you decide on any particular brand of camshaft.
Old Jan 23, 2007 | 10:25 AM
1 2 NV's Avatar
2000 wont get you ****. some cams, springs retainers, cam gears, and no headwork. might be lucky if you get a damn valve job out of it. keep spending, thats not going to do it.
Old Jan 23, 2007 | 10:27 AM
What are some good vtec cams
Old Jan 23, 2007 | 10:34 AM
98vtec's Avatar
moderator emeritus
https://honda-tech.com/zerosearch
and reported.
Old Jan 23, 2007 | 10:48 AM
https://honda-tech.com/zerothread?id=993338
https://honda-tech.com/zerothread?id=1368033
https://honda-tech.com/zerothread?id=1442416
A quick search yielded these 3 threads and MORE.
Old Jan 23, 2007 | 11:35 AM
f@sth@tch89's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 2 NV &raquo;</TD></TR><TR><TD CLASS="quote">i hate to say it but this is the type of **** belben was talking about. this would be better off locked and deleted.
if you want 200WHP you will have to spend money period. quit being cheap cause HP costs money.</TD></TR></TABLE>
i dont care for these type of posts...i hope i never create one.
for 200whp...geez...he better get some ctr pistons in that bad boy along with those jun3 cams, retainers, springs, aftermarket manifold, itr headers, and a 64mm TB....coh yeah and a chipped ECU
on my first motor built, it was a b16a block with a gsr head. i had ctr cams and pistons, skunk2 manifold, stock injectors, obd-0 harness, pr3 chipped ECU by ERE, pNp head from alaniz with itr outters and portflow inners....i think it was around 190ish to the wheels...tuned by Oshimo @ ZeroFactory
2nd motor: crvtec
s2s3 cams
je pistons 13.5:1
skunk2 manifold
str 68mm TB
370cc injectors
pr3 ECU reprgrammed by ERE
pnp GSR head w/ supertech valvetrain
4-1 race header
tuned again by ERE and Oshimo made 222whp
so keep on trying buddy....u got a loooooooooooong way to go...good luck
Old Jan 23, 2007 | 12:30 PM
Lip's Avatar
Lip
Default Re: jun (f@sth@tch89)
search search search. wasting time. you can probably post this in the integra forum...they might reply
94typeR
12
Jul 10, 2007 06:18 PM
bigislandc2
Jan 14, 2007 04:28 PM
jetmech53
Sep 12, 2005 02:07 PM
Petah
25
Jul 15, 2004 05:02 PM
JSJ EG6
10
Nov 15, 2003 02:06 PM
