code 6 for coolant temp sensor
my crx would always start right up, then out of no where it was throwing a code 7 for the tps sensor, then that went away after fiddling with it and for the past month its been a code 6 for the coolant temp sensor, is this the sensor on the side of the head or the back of the block?? i though it was my grounds by the thermostat but ive fixed then and still the same ****, car hardley starts because the ecu is in limp mode when the code is one, sometimes the check engine light with go right off like its supposed to and other times it stays on and is a pain to start, when its off , it fires right up, any help would be appriciated. thanks.
its on the side of the head, really easy to swap out, just make sure to put your thumb over the hole if youre not draining your coolant to change it.
