error code 6 ect
Old Jun 29, 2009 | 07:29 PM
goldfinger93030's Avatar
Default error code 6 ect
So, I replaced my wiring harness and now i keep getting error code 6 which is engine coolant temp does anyone have any ideas? Thats the only code I have and it didnt have that code before i took out the harness and I took it out because I was having trouble with the wiring for the secondary o2 sensor.
Old Jun 29, 2009 | 07:54 PM
ek-g6's Avatar
Default Re: error code 6 ect
How is the coolant temp sensor plug? is it cracked, or are wires frayed, it might just be loose connection, or the sensor itself is bad.
Old Jun 29, 2009 | 08:03 PM
is that ganna be the sensor on the thermostat or the sensor under the the vtec set up (still on the head)
Old Jun 29, 2009 | 08:04 PM
ek-g6's Avatar
Its on the head, and has one wire i believe.
Old Jun 29, 2009 | 08:16 PM
o its the pull out one? yeah that should be on right and not cracked
Old Jun 29, 2009 | 08:55 PM
Icon_Ed6's Avatar
the single wire plug on the head isn't coolant temp for the ecu its coolant temp for the gauge. The one for the ecu is the 2wire plug next to it.
Old Jun 29, 2009 | 08:59 PM
Icon_Ed6's Avatar
Also, FYI... the one on the thermostat isn't really a sensor its a fan switch. Good luck figuring it out
Old Jun 30, 2009 | 08:58 AM
alright cool um by any chance do you know the colors for the wires on the sensor?
Old Jul 8, 2009 | 09:04 AM
so after checking some stuff, i replaced my ect with a new one and the code went away so i took the car for a test drive. once i got down the street the check engine light started to flash code 6 again so i pulled over and rest the ecu. the code went away then the car sat again untill this morning and the same thing happened. i reset it and it went away. so would this mean that there is something wrong with the sensor the harness is uncut.
Old Jul 8, 2009 | 05:55 PM
bump
Old Jul 8, 2009 | 06:01 PM
Former User's Avatar
What year?
It could be the two ECT wires, the ECU connector with the ECT wire, or the ECU.
Old Jul 8, 2009 | 06:27 PM
the car is a 98 civic hatch with a b16a2 and the harness is a 96-98 ex and its the stock p2t ecu
Old Jul 8, 2009 | 07:43 PM
Here are the ECT wires to check:
Old Jul 8, 2009 | 07:47 PM
does it make it difference if i dont have my iat plugged in
Old Jul 8, 2009 | 07:49 PM
If the IAT is not plugged in, then why aren't you throwing an IAT code rather than an ECT code?
Old Jul 8, 2009 | 07:59 PM
it throws both
but if i plug up my friends iat sensor it goes away
Old Jul 8, 2009 | 08:04 PM
it throws both
Assuming the connectors are not swapped, the problems are separate. Why not get a new IAT sensor so that the engine runs optimally?
eghatchfla
May 28, 2010 06:26 AM
crxnatic
Jun 8, 2009 08:25 PM
CRX_RR
Jul 18, 2008 01:42 PM
mycrx7
Jan 23, 2007 11:21 AM
Mastuh4
Nov 3, 2004 09:49 AM
