kill switch
i want to install a kill switch on my 98 accord. my friend says i have to wire a switch to the fuel pump but i can't find the wire that goes to it. does anyone know where that wire is or if there's any other place i can wire the switch to ?
thanks in advance
thanks in advance
what the **** do you want a kill switch for?...
My guess is to layer his security so the car remains his? Maybe? You think?
Also, some racing organizations require this as a safety device.
Which ones??
Which ones??
a kill switch is very important in emergencies. Most rulebooks require the switch to be within reach of the driver side window
Depends on the rules. they're not all the same. most that I've read, require it to be within reach of the driver and accessable from outside. for example, mine is where the sunroof buttons used to be on the left side of the steering wheel.
I think in drag racing, they allow it to be in the rear.
actually it has to be within reach of track worker if the car was to roll over or be impacted, if you were to be knocked out you want it to be within reach of an outside person
you wouldn't want i on the back of the car because if impacted from the rear the car would be likely not to run anymore
thanks in advance
thanks in advance
Simple
13
Jan 10, 2004 07:57 AM
