kill switch
Old May 16, 2002 | 02:38 AM
j0se's Avatar
Default kill switch
i want to install a kill switch on my 98 accord. my friend says i have to wire a switch to the fuel pump but i can't find the wire that goes to it. does anyone know where that wire is or if there's any other place i can wire the switch to ?
thanks in advance
Old Nov 11, 2002 | 01:23 AM
hatchback's Avatar
Default Re: kill switch (j0se)
search.
Old Nov 11, 2002 | 03:45 AM
urbanlegend21's Avatar
New User
Default Re: kill switch (hatchback)
what the **** do you want a kill switch for?
Old Nov 11, 2002 | 04:42 AM
WuWarrior's Avatar
In my car, the kill switch is directly connected to the battery.
Check the rulebook wherever you are racing for any rules regarding this before you install it.
Old Nov 11, 2002 | 07:27 AM
MestizoRacer310's Avatar
Default Re: kill switch (urbanlegend21)
My guess is to layer his security so the car remains his? Maybe? You think?
Old Nov 11, 2002 | 07:29 AM
WuWarrior's Avatar
Default Re: kill switch (TeamDynasty91AccordEX)
what the **** do you want a kill switch for?...
Also, some racing organizations require this as a safety device.
Old Nov 11, 2002 | 07:52 AM
Default Re: kill switch (WuWarrior)
Which ones??
Old Nov 11, 2002 | 08:07 AM
WuWarrior's Avatar
Default Re: kill switch (MestizoRacer310)
Which ones??
I know IMSA required this, that is why my car has one. NHRA also requires this as well as many other organizations. it is a very common rule.
a kill switch is very important in emergencies. Most rulebooks require the switch to be within reach of the driver side window
Old Nov 11, 2002 | 08:13 AM
jweller's Avatar
Really??? most of the times I see one its on the rear bumper.
Old Nov 11, 2002 | 08:21 AM
WuWarrior's Avatar
Default Re: kill switch (jweller)
Depends on the rules. they're not all the same. most that I've read, require it to be within reach of the driver and accessable from outside. for example, mine is where the sunroof buttons used to be on the left side of the steering wheel.
I think in drag racing, they allow it to be in the rear.
Old Nov 11, 2002 | 08:34 AM
New User
actually it has to be within reach of track worker if the car was to roll over or be impacted, if you were to be knocked out you want it to be within reach of an outside person
you wouldn't want i on the back of the car because if impacted from the rear the car would be likely not to run anymore
Old Nov 13, 2002 | 12:02 PM
93acclude's Avatar
thanks in advance
you can also wire it to the batt, starter or the clutch starter swich if it is a 5m. It is just a matter of finding the right wires and knowing what they do. I would suggest going to your local honda dealership and asking if you could look at the electrical schematics for your car. You might even be able to convince a friendly tech to give you some input.
Old Nov 13, 2002 | 01:46 PM
notoriousB's Avatar
you can get the fuel pump wire from the fuse box on the drivers side, i think it's black/yellow but check a wiring diagram to be sure
jorgejam2001
Sep 11, 2010 07:23 AM
civicexowner
Dec 22, 2007 04:04 PM
underpressure02
Apr 23, 2007 08:42 AM
FGride
Audio / Security / Video
Apr 26, 2006 12:43 AM
Simple
13
Jan 10, 2004 07:57 AM
