Screws on rotor's. Help removing them.
Old Jan 21, 2007 | 11:25 AM
Discontained's Avatar
Default Screws on rotor's. Help removing them.
I bought new rotor's and brake pad's the other day, and when i went to install them I could not get the freaking screw's off. Is there a way. I thought about drilling them, but im not sure if they are needed. Any help would be appreciated. Tried searching didnt come up with alot.
Thanks
-disc0
Old Jan 21, 2007 | 11:30 AM
fireant's Avatar
Default Re: Screws on rotor's. Help removing them. (Discontained)
You need to get an impact screwdriver.
http://autorepair.about.com/li...b.htm
Its like a screwdriver with a mechanism inside it that will turn when you whack it with a hammer. They are fairly affordable if you look around. You can try to mutiliate and drill them out, but its a huge bit-eating hassle compared to one or two whacks with an impact screwdriver.
Old Jan 21, 2007 | 11:34 AM
MatHadder's Avatar
Default Re: Screws on rotor's. Help removing them. (fireant)
Yeah, the impact screwdriver is the right way to do it.
Old Jan 21, 2007 | 11:39 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: Screws on rotor's. Help removing them. (MatHadder)
in a worst case you can just use a regular phillips with a hammer and twist your hand left while hitting it, it works most of the time too
Old Jan 21, 2007 | 11:40 AM
SmogKing's Avatar
rent one at autozone.
Old Jan 21, 2007 | 11:46 AM
allmotor215's Avatar
Default Re: Screws on rotor's. Help removing them. (SmoGuy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SmoGuy &raquo;</TD></TR><TR><TD CLASS="quote">rent one at autozone.</TD></TR></TABLE>or buy one @ sears for 25 bucks
Old Jan 21, 2007 | 11:52 AM
Nick_Drake's Avatar
I just took a phillips head that fit in there tight, it's got to be a dull-tipped kind, and hit it with a hammer. That held it in pretty good for me to be able to loosen them. I do plan on ditching them next time I change my rotors though.
Old Jan 21, 2007 | 01:11 PM
Boosted Chemist's Avatar
Default Re: (Nick_Drake)
Just drill the heads off with a 1/4 drill. They are soft brass. Let the Then pull hte rotor off and use a vise grip to pull them out the rest of hte way.
Old Jan 21, 2007 | 01:13 PM
AJxr's Avatar
Default Re: (Boosted Chemist)
just invest in an impact driver
Old Jan 21, 2007 | 04:04 PM
thanks guys i got them off with that tool at sears, and got some replacement screws to put them in.
GG
-disc0
Old Jan 21, 2007 | 04:46 PM
Crx Jimmy's Avatar
Default Re: (Discontained)
I got one of those tools from harbor freight for $5 and it was well worth it but if anyone searches in the future, yes you can drill them out very easy they are made of a super soft metal and can be easily drilled out
MadCityLude
Nov 26, 2005 05:42 PM
Consistent1
Jan 14, 2005 02:32 PM
highmilehatch
Apr 10, 2003 02:00 PM
deviant1
Dec 21, 2002 04:21 AM
BD7581
Aug 20, 2002 03:58 PM
