93 del sol power steering HELP!
Old Jan 21, 2007 | 08:26 AM
acuteviet's Avatar
Default 93 del sol power steering HELP!
i have a del sol w/ jdm b16 motor but previous owner took all the power steering stuff out.
What are the stuff that i need to put everything back? Please if you can list all the parts are needed, thank you in advance!!!
Old Jan 21, 2007 | 08:30 AM
sohcvtec1995's Avatar
rack, lines, pump, fluid, brackets. best thing to do is just get a wrecked car with the stuff and transfer everything.
Old Jan 21, 2007 | 09:18 AM
acuteviet's Avatar
Default Re: (sohcvtec1995)
doesn't sohc ps pump bolt on difference then dohc vtec?
im pretty sure there is a difference between those 2...
Old Jan 21, 2007 | 09:29 AM
vtec4lyfe's Avatar
I don't know if you understand how much work it is to put it back in, you will have to drop the sub frame and also bent custom hard lines most likely. its going to cost over 2 grand if you dont know what your doing. I have a 00 ek and i would love to not have power steering buts its a lot of work
Old Jan 21, 2007 | 09:35 AM
nsxmatt's Avatar
Default Re: (vtec4lyfe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec4lyfe &raquo;</TD></TR><TR><TD CLASS="quote">I don't know if you understand how much work it is to put it back in, you will have to drop the sub frame and also bent custom hard lines most likely. its going to cost over 2 grand if you dont know what your doing. I have a 00 ek and i would love to not have power steering buts its a lot of work</TD></TR></TABLE>
Read the post, he already had it on the car but the previous owner removed it. The only thing he would need is the parts the previous owner removed and a B16 bracket and PS pump. All that can be bolted on.
Old Jan 21, 2007 | 09:37 AM
pdiggitydogg's Avatar
Do you still have the PS rack, or was it swapped out to a manual?
(Maybe just ps rack w/ looped fittings)
Depending on how you answer that, it could be fairly inexpensive and simple
Old Jan 21, 2007 | 09:38 AM
acuteviet's Avatar
dam, but will the rack mess up if the holes are open. i've heard you can't seal tight those 2 holes on the rack.
Old Jan 21, 2007 | 09:43 AM
acuteviet's Avatar
Default Re: (pdiggitydogg)
yes it is a ps rack. just the lines, bracket, pump, resev. are gone. just left w/ 2 empty holes on the rack.
Old Jan 21, 2007 | 10:01 AM
You will want to flush the rack VERY well...
Then, get your lines, pump, brackets, reservoir
Old Jan 21, 2007 | 01:04 PM
acuteviet's Avatar
Need to know what year and model i can get these parts from!
lines:
bracket:
pump:
reservoir:
Thanks!
Old Jan 21, 2007 | 01:23 PM
EG/DC lines
B series lower bracket
B16 upper bracket
Integra 94+ pump (NOT from a 99-00 si)
Reservoirs are probably all the same...probably...
Check the classified ads here, ebay, and junk yards.
I have a teg ps cooler line, btw
Old Jan 21, 2007 | 01:50 PM
acuteviet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">
B16 upper bracket</TD></TR></TABLE>
wth, i didn't know there are two brackets for ps.
i thought there's only one ps bracket.
Unless you're referring to lower engine torque mount (on the a/c side).
Old Jan 21, 2007 | 01:59 PM
no
there is a bracket that bolts to the block and one that bolts to the head
The block bracket is directly above the tq mount bracket
Old Jan 21, 2007 | 02:09 PM
acuteviet's Avatar
holly ****, i never knew there's a bracket above the tq mount.
I only saw the bracket that bolt on the head which is for ps.
Old Feb 7, 2007 | 02:11 PM
acuteviet's Avatar
which one will i need the gsr/ls ps pump? i heard its different. what about the upper bracket does it have to be from a b16 or any b series? i have all the eg ps lines.
Thanks in advance...
Old Feb 7, 2007 | 02:33 PM
https://honda-tech.com/zerothread?id=1822781
that will answer both questions...just read it
Old Feb 7, 2007 | 09:45 PM
acuteviet's Avatar
pic goes a long way, thanks man!
now i know what i need to get.
Modified by acuteviet at 1:27 PM 2/8/2007
nerD_alert
May 21, 2012 07:10 PM
theonecalledtodd
Apr 18, 2007 01:11 PM
