93 del sol power steering HELP!
i have a del sol w/ jdm b16 motor but previous owner took all the power steering stuff out.
What are the stuff that i need to put everything back? Please if you can list all the parts are needed, thank you in advance!!!
I don't know if you understand how much work it is to put it back in, you will have to drop the sub frame and also bent custom hard lines most likely. its going to cost over 2 grand if you dont know what your doing. I have a 00 ek and i would love to not have power steering buts its a lot of work
Re: (vtec4lyfe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec4lyfe »</TD></TR><TR><TD CLASS="quote">I don't know if you understand how much work it is to put it back in, you will have to drop the sub frame and also bent custom hard lines most likely. its going to cost over 2 grand if you dont know what your doing. I have a 00 ek and i would love to not have power steering buts its a lot of work</TD></TR></TABLE>
Read the post, he already had it on the car but the previous owner removed it. The only thing he would need is the parts the previous owner removed and a B16 bracket and PS pump. All that can be bolted on.
Do you still have the PS rack, or was it swapped out to a manual?
(Maybe just ps rack w/ looped fittings)
Depending on how you answer that, it could be fairly inexpensive and simple
EG/DC lines
B series lower bracket
B16 upper bracket
Integra 94+ pump (NOT from a 99-00 si)
Reservoirs are probably all the same...probably...
Check the classified ads here, ebay, and junk yards.
I have a teg ps cooler line, btw
B16 upper bracket
Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">
B16 upper bracket</TD></TR></TABLE>
wth, i didn't know there are two brackets for ps.
i thought there's only one ps bracket.
Unless you're referring to lower engine torque mount (on the a/c side).
Re: (pdiggitydogg)
holly ****, i never knew there's a bracket above the tq mount.
I only saw the bracket that bolt on the head which is for ps.
which one will i need the gsr/ls ps pump? i heard its different. what about the upper bracket does it have to be from a b16 or any b series? i have all the eg ps lines.
Thanks in advance...
nerD_alert
05-21-2012 07:10 PM
