what kind of sleeves are these??ANYONE??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">Looks like stock sleeves bored out with a block guard in it. </TD></TR></TABLE>
thats some good machining. looks like its one whole piece tho
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects »</TD></TR><TR><TD CLASS="quote">thats some good machining. looks like its one whole piece tho</TD></TR></TABLE>
Yea i thought it was one piece too but if you look around where the sleeves are you could see a line where there not one piece. Look more on cylinder 1, 2 and 3 you cant really see it on 4.
not block guard, its sleeves some said they were sleeve inserts.... i want to use it an boost it but i want to know it i can do 14lbs on it ?????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EX-T »</TD></TR><TR><TD CLASS="quote">You can run 14 psi on stock sleeves depending on the turbo.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EX-T »</TD></TR><TR><TD CLASS="quote">You can run 14 psi on stock sleeves depending on the turbo.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EX-T »</TD></TR><TR><TD CLASS="quote">You can run 14 psi on stock sleeves depending on the turbo.</TD></TR></TABLE>
And the tune. Compression test, mainteneance.
