once my car is warmed up my idle will drop to the point of almost shutting off then bounce up again
Old Jan 20, 2007 | 04:34 PM
piggydog's Avatar
Default once my car is warmed up my idle will drop to the point of almost shutting off then bounce up again
In the morning everything is fine cause my idle is high but once the car is warm if I come to a stoplight or I'm coasting in neutral my idle will drop so low that it will almost shut off the car. What could be causing this?
Old Jan 20, 2007 | 04:47 PM
Hawkze_2.3's Avatar
Default Re: once my car is warmed up my idle will drop to the point of almost shutting off then bounce up ag
Idle screw on the throttle body and a valve adjustment are the 1st things I would try. Also check the TPS, FITV and IACV.
skata89
Jun 3, 2006 12:58 PM
faSHOwidIT
Mar 25, 2005 02:07 AM
SilverSellout
12
Feb 27, 2004 12:48 PM
killa_lude
Aug 16, 2003 08:33 AM
